Old 07-01-2009, 09:53 PM   #2 (permalink)
hmathews
Romans 3:21-26
Yes you are right - you cannot do EGR delete without doing the DPF delete atleast what I understand. And without the deletes your DPF & CAT filters are going to be plugged often and you will get CEL messages and limp mode and shorter engine life and all that kind of stuff...
I have the H&S kit with the downpipe. I believe that's the way to go because it gets rid of the CAT filter in the downpipe as well. Almost all of the guys in the forum has the stage 2 I believe.
If I am not mistaken there is a post in the 6.7L articles section of the forum where you can actually make a DIY downpipe and delete kit. If you are good with things like that you can do it yourself, if you have tools for cutting etc. I assume. I haven't looked too much into it since I knew I wasn't going to be able to do it myself..
I think you still need a programmer to clear codes after the delete because it will throw a soft code. I don't know if H&S has worked this out - I got my kit a long time ago... and there have been many updates since then.
You can do all the install yourself. It will take couple of hours. No welding/drilling. Everything is bolt on. You may need an extra hand because the stock exhaust is so heavy and it is a pain to take the down pipe out...
I bought my truck 29K miles used... had to make a few trips to the dealer in the first couple of months, decided to do the deletes -now it is sitting at 55k miles and have not had any issues. Probably never going to see the dealer again...
2007.5 RAM 2500 MegaCab (Black), 6.7L Cummins... Auto, 2WD, Truck came with no DPF and EGR, Smarty 67 ME, EDGE w/Hot unlock (turned to zero), MP-8 (turned down to zero - soon to be for sale), S&B CAI, RAAMMAT soundproofing (mostly done), Bilstein 5100 shocks, Rear wheel well liners, Access Loredo roll up cover.
hmathews is offline   Reply With Quote
