Old 06-30-2009, 11:45 PM   #2 (permalink)
Just Another Cummins
Just Another Cummins's Avatar
You should get high pressure stems, or bolt in stems.
I am partial to bolt in stems because they are almost indestructable, I haved seen a few high pressure stems have the rubber separate from the shaft, I've only seen it 3 times in the thousands of tires I have worked on. I have high pressure stems in my truck and I plow with it with no problems.
If I ever have a problem I'll go to bolt ins, but until then, high pressure stems will be good.
01 QC SB 47RE
Tint, Raptor 150-DSV, 4" MBRP, 265s, soon to be more
2590.8 MM Western Straight Blade
Just Another Cummins is offline   Reply With Quote
The Following User Says Thank You to Just Another Cummins For This Useful Post:
gotacummins (07-09-2009)
