Thread: modded VGT's
Old 06-30-2009, 02:24 PM   #4 (permalink)
qualmq
Originally Posted by theicon2u View Post
Fleece makes an 66mm and Industrial Injection makes a 64mm. Im going to go with the 66mm from Fleece. Fleece told me that I would see a 250 drop in EGT's and make about 45 psi boost. I would have a drive pressure issue anymore. The exhaust brake will work better also. They also said it spools just as fast as stock. II told me the same but they where only seeing 150 drop in EGT's.
How much are they charging for this upgrade? PM me if you dont want to post it up please.
2008 6.7 CTD, 6" superlift, PSC steering brace, 35's on 20's, 5" TBE, AFE intake, Smarty, Airdog 150, ATS Head studs, DPF/EGR deletes, Isspro Performax gauges, home built 3 1/2" intake tube
qualmq is offline   Reply With Quote
