Old 06-29-2009, 08:02 PM   #4 (permalink)
Stump Jumper
Stump Jumper's Avatar
Originally Posted by ykdave View Post
Thats what i thought too...
Maybe what they meant by that was a 14cm turbine housing on an hx40 would spool/flow similar to a 16cm housing on an hx35...?
Thats what I am trying to figure out I agree with you 2 that I though a 16 was a 16 no matter what turbo size. It just refers the the internal volume of the housing it what I thought anyway.
The only place I had seen it was on that site and now I cant find it to read it agian an make sure I read it right even thoe I read it 3 or 4 times befor to make sure I was reading it right at that time If that is the way it is then instead of having a 16cm housing I have a 18cm cause I have a 16cm HX40 housing on my HX35
97 12 valve HX40/HT60 Twins, 0 plate FF, 2095 plug, AFC tweaked , 4k gov, 16*, Weston's 5X.014s, 5in from turbo to stack, Twin Ram, HTT manifold SB 3250 DD Gauges up the wazoo.
Stump Jumper is offline   Reply With Quote
