Originally Posted by tclappcummins
I strongly disagree... I had death wobble and could NOT fix it what so ever... I completely replaced my front end... still no fix, so I got different rims and tires and problem fixed
That's pretty vague. I'm still not convinced it was your rims/tires... or if it was your rims or tires, it wasn't exactly what people call "death wobble" - could've been a balancing problem or a bad tire.
What kinda tires were the "bad" ones?
Many times, the death wobble comes from a levelling kit or lift changing the geometric relationship of your control arms / shocks. Plus, if you level your truck up, it always shifts the front axle toward the driver's side an inch or more. Then you NEED an adjustable trackbar (like a DT or Skyjacker) so you can center the front axle again.
Was your "death wobble" before or after you levelled your front-end?
Another cause of death wobble is steering box flex. An SBS (steering box support) kit removes all the problematic flex. BD makes one.. the original one was the Windecker Machine kit if I'm not mistaken. I need one of those BAD!!
I am getting the BFG M/T KM2's and a Skyjacker adjustable trackbar installed today (w/ an alignment)... hopefully that will at least partially solve my front-end woes.
98 12valve QC LB 4WD w/ 170K [new Goerend 47re, DDP fuel plate, AFE ProGuard7, MBRP 4" TB w/ 5" tip, Thuren trackbar, Bilstein 5100's, 2.5" Revtek level kit, BFG Mud KM2 33x11's, AWC 16x8 rims, Amsoil, silencer ring gone, KDP tabbed (THANKS Nitrous340!)
