Thread: rear locker!!!
Old 06-24-2009, 07:46 AM   #8 (permalink)
Philip
1ST GEN MODERATOR
Philip's Avatar
Any power lock for a Dana 70 with 35 spline will work. 3:54 to 456 ratio is the one you want. The 3:07 uses the same carrier as the 3:54's do. You could even use a 35 spline ARB air locker if you wanted.
Its best to pull an axle to make sure if it is 35 spline. You never know about Dana corp.
Philip is online now   Reply With Quote
