Old 06-24-2009, 01:51 AM   #4 (permalink)
65StangBoy
65StangBoy's Avatar
3rd Gen. Isspro EV2 Gauge Install
Transmission Oil Temperature Gauge
I wanted to get the most accurate reading so I purchased a replacement transmission line from Diesel Manor with a sender port already installed.
Installation was pretty straightforward. Clearances are a little tight around the transmission due to the front driveshaft but take your time and you'll get it no problem. Just make sure you have a drip pan as you'll lose a decent amount of fluid when you remove the old line.
Terminate your two wires going to the sender and you're done.
Finished Product
Gauges wired, Weather Pack connectors terminated, and wires secured.
Weather Pack connectors.
Stick a fork in it.
2006 Dodge Ram 2500 QC/SB Big Horn Edition
Quadzilla Xzillaraider 2 Race Module, 5" Turbo Back Exhaust, BHAF, Leveling Kit w/ 35's, ISSPRO EV2's-Pyrometer, Boost, Trans. Temp.
65StangBoy is offline   Reply With Quote
