I looked on Tire Rack to see what they recommend for that size tire and at least for the tire shown 9" is at the upper end of recommended.
Tire Specs for Goodyear Wrangler AT/S
I don't think the link worked right; but if you go to tirerack.com and input the size tire you want and pick the tire you want and click on specs it should tell you what size rim will work.
1996 3500 4x4 SLT extended cab 5 speed with 4.10:1 and Gear Vendor Splitter and airbag suspension, pyrometer and boost gauges.
