Originally Posted by R&DFabrications
im a bit confused. why would the mounts be different from different sized shocks? the only two reasons for changes in coilover/shock size are rod strength(not necessarily body diameter change) and fluid capacity change to compensate for higher boiling temperatures necessary to extreme offroad use. ive seen both of the kits discussed, and theyre really nice, but the lack of a custom tower has always confused me. is it just to make the kit available as a bolt on? otherwise wouldnt a custom tower with a crossover brace be the only way to go? my backround is desert, but of the few full size custom coilover conversions, none higher than 10 inches, ive built, we ALWAYS utilize a custom tower mainly for fear of the frame tearing away or bending outward due to the stress, not to mention a cummins twists frames anyways. little lost as to the longevity of one of these kits without the towers, and even still, what stops the full droop stress of a dual rated coilover compounded with nitrogen pressureized droop, and unsprung weight?
did you not read this post?
Originally Posted by firemansdiesel
The Starter System, 2.0 & ***2.5 System use clevisis or stem top w/ factory towers. They are for mild off road w/ great street ride.
Also the 2.5 system comes w/ Carli's aftermarket towers (the stem top I noted above is for guys who have the Starter or 2.0 system that want to upgrade to the King's w/o spending money on new towers). All other systems (2.65 & 3.0) come w/ Carli's towers. These systems are for off road speeds & of course great on road ride/handling.
Carli does alot of R&D in every possible driving environment before they release to the public (knowing such things like stock towers will not hold up to abuse to off road speed type terrian along w/ other flaws of stock components). That's why when a customer is unsure what system to get. Carli will point them in the right direction for thier truck use.
Dodge Ram Suspension Systems and Components by Carli Suspension
2012 Chrysler Town and Kuntry
Twanky Fo's wrapped in wide white walls
lifted 18"s by Two Up Offroad
