02-13-2007, 05:36 PM
#17 (permalink)
Just to be clear...
Originally Posted by WorkhorseDiesel
No, do not use the premium plus synthetic, it has additives that are not needed and not recommended. If the Pennzoil Universal is not available, I'd suggest trying the SuperTech, they come from the same refinery and have the same makeup. If you can't find the SuperTech Universal, the SuperTech Outboard should work well in it's place. I've found that the SuperTech Universal is NOT available in many parts of the country. So, if the Pennzoil Universal is not available, the SuperTech Outboard is the next best choice.
Workhorse,
When you say "Pennzoil Universai" in the quote above....... you are referring to the one on.. The List ... labeled Pennzoil Outdoor/ Multi-Purpose ???
Correct ? I just want to be clear I am using the right one.
Thank you......
Have a good one & remember....... "Your mileage may vary." <>< __________________________________________________ __________
1993 D-250 LE Club Cab ... 5.9 L / 360cid CTD ... 5 spd Getrag ... SRW
256,000 miles... 21.6 MPG Hwy.  MDH / 030817
..Pretty much stock as far as I know... ??? ... .... 160 hp / 400 ft.lb.
