Originally Posted by zstroken
You can retorque them. We are pushing 55psi through a24V and ran my12 for half of a pulling season at 55psi with 18 degrees timing. We torqued them to 120 ish cold if I remember right. Don't expect this to last forever, just to get you by.
did you just put a TQ wrench on there and go to 120 or did ya back them out a little and add lube then go to 120 thanks
also i dont plan on running anything over 40-45 psi till i get head studs anyways so
1997, 2500 CTD. 4x4 LWB, ext cab, MODS-#100 plate, JL Machine 5x0.016 Injectors, 3kgsk, timing at 16*, Dave G. trans, , HTT killer B II 64/14, Custom DV's from weston!!! Mods soon to be- traction bars,head studs, marine gasket.
