Old 05-09-2009, 11:03 PM   #19 (permalink)
jmd025
13.5grs of #2400
jmd025's Avatar
Originally Posted by duddy4 View Post
what about adjusting the rod on the wastgate, I'm only getting 27 psi with my setup will this help?? not sure if i understand i cannot j hook my wastgate??
Why couldn't you J-hook your wastegate? If you have a HY35 then yes you could.
You should see plenty more boost than your stock turbo will want with your setup once you get the wastegate right.
EDIT: I see you have a 99 model, which "should" have a HX35, so you would need a boost elbow, not a j - hook!
VE 90 D250: Pump mods, Isspros, Single Stack SOLD
P 98 2500: 215 pump, bone freakin stock
VP 02 2500: Airdog, Isspro, Valair, Amsoil, Vulcan Performance, Coaltrain , TST, TS Performance, Outerwears
jmd025 is offline   Reply With Quote
