Old 05-09-2009, 12:37 AM   #1 (permalink)
highrpms
highrpms's Avatar
Cleaning the MAP sensor w/Pics
As Marco talked about in another post it is a good idea to clean the MAP sensor.Many may already do this and many may not even know where the MAP is. Cleaning this sensor may really improve the way the engine runs and cut down on codes like P0106. Even if you think your truck is running good it will not hurt to clean this. This is about the simpest thing to do and takes about 5 minutes. Brake cleaner and a Torx #15 head is all that is needed.
Map location
Dirty sensor. My sensor had about 2000 miles before the EGR was deleted and it is tough to see by the pictures, but it is covered in soot. I can not imagine what some of the sensors are like that have had the EGR hooked up for awhile.
Clean sensor. You can now see the protected orange part in the middle.
2007 5.9 2500 4x4, BD Race twins, industrial Inj Twin CP3's, Industrial Inj Stage 2 Injectors, Smarty TNT-R stacked with Quad X2 CFM+ Built Tranny by Jason @ Diesel Nut FASS
2007.5 6.7 2500 4X4, Juice with Attitude, DPF delete and EGR Delete AFE stage 2 MP8
highrpms is offline   Reply With Quote
The Following User Says Thank You to highrpms For This Useful Post:
GA6.7 (11-07-2009)
