Old 01-29-2006, 10:43 AM   #11 (permalink)
DieselBurps
Originally Posted by AZBLACKSMOKE
Where do you get your filter bags from?
Search www.mcmaster.com for filter bags. There's also www.filterbag.com.
The fuel gauge probably isnt a bad idea. I am thinking of installing another filter on the truck. I havent had one single problem yet...but I think its still to early to tell. But the oil, temps, and general design of the trucks fuel system are on my side...so I think I'll be ok.
Just to clarify - fuel pressure gauge was the topic - I didn't want other readers to get confused here.
I thought about converting my truck to 100% WVO but this method doesnt fit my lifestyle. I only have a 10 mile commute to work. So the purging would be very time consuming and pointless. Thats why I decided to blend instead....I see the benefits of this right away....mainly...my wallet doesnt hurt as much and I can now drive more because the ole ladie doesnt freak out when it cost me $80+ to fill my truck up.
I've got a 4 mile commute - but I do make the occasional longer trip. My newly designed (and soon to be implemented) setup should allow me to switch to WVO in about a mile. Purge time shouldn't be that bad - when I switch back to diesel, the WVO should be purged down to a reasonable % mix within a 1/2 mile, and completely gone by 1 mile. That helps to cut my fuel consumption in 1/2. Blend by 50% also and it's down to 1/4! Also - if I head home for lunch and don't take too long at home, I can do ~ 6.5 miles of the 8 mile trip on WVO.
The final satisfaction comes in when I can finish up my biodiesel refinery and then do 100% of the trip off diesel!
DieselBurps is offline   Reply With Quote
