Originally Posted by DIESEL POWER
so how many grudge matches to i have to race :fist:
if you want to dyno you pay admission and $75 right?
if you want to race you pay for the racers ticket and your good right? how many passes are you allowing? any schedule for the day would be nice. thanks
Don't know how many Wade? But I can tell you one you will lose!!
:thumbsup
If you want to race, the "Racer Ticket" gets you (the driver) in the grounds and allows you to make passes down the track. You could also dyno if you would like. You can make as many passes as you would like between 9 AM to 4 PM. There is no "schedule" for racing. It is just like a T&T but, because of the limited number of racers allowed, there will not be the typical long waits in line. If you hot lapped it, you could get 30-40 passes in
If you are not racing, then you would pay the $10 ea. to get in the grounds and you can then either just spectate or dyno if you would like.
Greg 2000 F250 Common Rail Cummins
11.88 @ 114.19 @ 7800 lbs w/ 7.3 psd
MD-TDC Vice-Pres.
