Had the same problem in 2004. After going through several fuses, I found the problem to be the bulb socket contacts. Dealer had to replace the assy., and said this was common. I thought they had done a fix on this problem, but you might check anyway.
2003, SB Quad 2WD, 2500HD, Cummins HO 6 speed. Truck of my dreams!
