Bad fuel is still my guess. I was on the road delivering a horse trailer over to Indy and on my way home when it started. I make a point to fill up each time I stop for a break that way if someplace has bad fuel I don't end up with a full tank of it. Been there done that on a few trips.
I may be wrong but I am assuming that nothing is clogged because I still ran at least 60 miles with no LP's runnin. If something was clogged I shouldn't have made it home.
374.2/846.7 at 30psi
