The power comes right off the battery through a fused link. The fuse is good. It is activated by the stock trigger wire through a dual relay system. I traded the fuel relay in the fuse box under the hood when I was having problems and it didn't change anything. The ground wire is also right off the battery connection so I am assuming that ground is good.
PS. Keep thinking out loud, I need all the ideas I can get.
374.2/846.7 at 30psi
