Okay, so I wanna tweak the chapter logo. The one I came up with uses a truck that worked at the time, but really isn't genre correct, nor a current member's ride. So.....
I would like to have images EMAILED (not PM'd) to me by members who have the ability to take a hi-res picture (at LEAST 1000 pixels) Each member should send me 3 images, one straight on, one from a left angle and one from a right angle. The best way to shoot automobiles is to take the picture away from the normal viewing angle. I would like the images to be taken from close to the ground looking up at the vehicle at angle that roughly shows the entire side, but makes the front end prominant. Looking at the example logo you will see what I am after. So use that, but include shots of both side angles and a straight on, again, from a lower vantage point.
Once I accumulate enough images, I will put up a poll and let everyone decide which trio to use. I would like to see a 1st, 2nd, and 3rd gen truck all three in the logo, and in a perfect world, all of the same color and roughly the same exterior look as pertaining to tire size and lift if applicable. After we vote on it, a new proof will be available to critique. This logo is important, as it will be the unified logo for ALL the chapters and will be used in a lot of mediums.
Thanks guys
Chris
In NW Florida? Get a hold of me...it's time Dodge makes it statement in these parts!!
'95 2500 Std Cab 4X4... DTT billet trans and billet triple disc, billet flexplate, compound turbos, AEM Dryflow, 160 pump, custom plate, 191's, EDM370's, peaked and tweaked AFC, rack control plug, 20*, 3K, head studs, marine +.020 HG, Water/meth
