Old 01-28-2007, 09:19 AM   #3 (permalink)
99 cummins
These pumps are side by side, not in series. They both feed independantly of each other as far as fuel goes. The only place they feed together is from the trigger and power from the battery.
I need some quick help on this. I'm supposed to already be headin cross country movin the first load.
374.2/846.7 at 30psi
99 cummins is offline   Reply With Quote
