Originally Posted by Mikey-Mike
Will this help make the rear brakes grab more so the front disk's don't take all the abuse of stopping??
My pedal seems to be about half way to the floor before braking occurs and seems the front's are doing most of the work.
yep, yer changing out 24mm bore cylinders for a 30mm bore. the one tons are 27 mm i believe i read. pedal being low is probably just the rears needing adjustment. The auto adjusters on the rear are about useless, I adjust mine when i change oil. sometimes they are fine sometimes i find one that is off quite abit. I cannot figure the adjusters out had em off 20 times trying to see why and they should work!
Dog's truck:95 2wd ex, built auto, kdp tabbed, 3 disc billet converter,3.54 gears, 4gsk, bhaf, 0 plate, rack plug, 90hp injectors, 191 DV's, htt 62/71/14, timed @17*, 60# valve springs, head studs, 5" exhaust, gauges
