Old 03-10-2009, 01:59 AM   #7 (permalink)
ClayCountyCummins
ClayCountyCummins's Avatar
Originally Posted by RedRum View Post
when you say coil spacer, do you mean just a leveling kit? Did you have to get longer shocks? What about the trackbar? I've been wanting to do this, but advised by Superlift that it would cause bad geometry and driveline angles.
yea, a "leveling kit" is a coil spacer. i ran a 2.5" coil spacer
the shocks i ran were bilstien 5150s from the 6" superlift kit. and i had the dual shock mount essentially giving me 3 shocks.
i did not do anything different to the suspension, just 6" super lift kit with the coil spacer
as for superlift saying the geometry and drive angles being off, they are correct the geometry and drive angles would be not what the were intended for but the extra added lift will not hurt it, it will perform just fine
-2008 Dodge 2500 Cummins 6.7L Quad Cab SLT (Super Black) with lots of go fast parts...big tires and lift and built Suncoast transmission
ClayCountyCummins is offline   Reply With Quote
