Most likely not...as the ones you are talking about aren't exhaust brakes, they are engine brakes...they do something with the valves inside the engine..essentially if my hunch is correct they hold shut the valves so that the compression of the engine slows itself down. But they will make a distiquished sound through the exhaust when they are on, but not the really loud "popping" sound like you get on an engine brake such as the Jake brake.
'01 2500 4x4 QC/SB, 4" straight pipe, Amsoil intake, Autometer gauges,Smarty,Edge Comp Hot,Holley Blue,HX40,Recon roof led's, manual high idle, built up auto trans, 89% stall TC
'07 Chev 2500 CC/LB Duramax LBZ Edge Juice with Attitude
