Old 01-08-2009, 04:32 PM   #20 (permalink)
illflem
Moderator
Save yourself a lot of work and experimenting.
Here's the place I was thinking of http://www.badlanzhpe.com/page6.html
It's been a few years but he told me he would set me up with a 4" valve, two weld on flanges w/ gaskets for it, all the wire including a nice looking shifter mounted switch for around $175. He would provide clamp on flanges for the same price.The set up without the flanges is still $150 so I guess the price hasn't changed much. Very nice looking products.
The gasser racer guys use these valves to bypass the muffler with a Y in the pipe.
Please remember if you have the butterfly closed anything over an idle will cause engine damage even with a hole drilled in the butterfly.
That's the reason all the e-brake manufacturers have a switch on the throttle linkage.
Sort of the same reasoning why you use your right foot for the throttle and brake, so you don't do both at the same time.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Not stock
