Old 01-07-2009, 01:42 PM   #1 (permalink)
M K
Headlight high beam ???
When I turn on the high beams should the low beam filament be on or off ? Right now the low beam filament turns off when the high beam filament is on , it seems to me that both HI & LO should be on when the bright light are on . If both should be on how would I fix the problem is there a relay or something ?
97 - 2500 club cab 8ft box , 2 wheel drive auto trans 4:10 rear end , BHAF,heat shield & AFE intake tube, Autometer boost, pyro ,trans temp guages , stock afc plate moved forward , AFE 4" stainless turbo back exhaust , Alpha bed liner ,repainted white
M K is offline   Reply With Quote
