Old 11-30-2006, 01:05 PM   #16 (permalink)
MotorCityMadman
That is the same one I saw on my son's 95. Previous owner had it installed. I also when to the wrecker and bought the solenoid (75-newer carbed/air conditioned Chev) for $5. The only difficulty is is making the bracket which can be made from a 3x3 piece of metal folded, ground and drilled. It works well, you rev the engine manually above the solenoids limit and turn it on. It does not have enough power to move the throttle from idle but will hold it after it is actuated.
MotorCityMadman is offline   Reply With Quote
