A sway bar would help the road manners way more than tweaking the spring rate. Just disconnect it when off road to get your flex back. Also they should figure out a way to incorporate a steering box stabilizer into it. That one rod with heims on either end is a good idea but is only half there.
04.5 6 spd dually,Smarty,MP8,Isspro performax,II twins,arp,FASS,bd ic,ats arc, winnspeed heater delete,SB DD 3850#,flux2,Hamilton's,maghitec,Spirson 6", toyo,defiant sbs, Sulastic's, dynatrac hub's, cognitto traction bars, Carli LT bags, amp steps, oasis
