Originally Posted by red24v
dan i got the little fass pump on my first rib of box where the bracket fits any ways it is buzzing noise so as i was thinking can i put rubber bushings between the bracket and the rib will i stop the noise or is it just a sound i have to put up with not that its really bad but you can sure hear it pump
A lot of guys are using an old mud flap to isolate the HPFP bracket off the bed. This, i have heard, makes a huge difference. As for the pump its self, we talked to our motor guy. He said that the brushes in the motor take about 40-60 hrs of run time to "ware in" to the motor armature. Its basically a flat brush wearing to a curved surface. The resistance is high at first, but then as the brushes ware in, the resistance drops and the motor should be less noisy. BUT our pumps will make some noise. .
Dan MacDonald
2002 TDI Jetta...stock for now
