Safe EGT and Boost. - Dodge Cummins Diesel Forum
post #1 of 27 (permalink) Old 08-05-2008, 11:19 AM Thread Starter
Regen? What's That??
azpyroguy's Avatar
Safe EGT and Boost.
I just installed a Edge Juice w/Attitude, and a AirAid CAI kit. As well as getting ready to install a RBP DPF Back Exhaust.
I currently have the Juice on Level 2, with Medium response, and wow... what a difference...
Questions:
What is considered the safe EGT on these motors, from previous experience experience on the Gen 3's it was 1350, but these new motors with the DPF operate higher by default.
Right now I have the Juice set to defuel at 1350 EGT, and alert me at 32lbs of boost.
I know when I add the RBP exhaust I will loose about 100-150 degrees of EGT.
Right now if I mat it hard and around 2300-2500rpm, she will hit 1376 degrees for a moment and then back down withing a second or two, but the Attitude alerts me (as it should).
What are your experinces regarding this?
07 3500 QC DRW, 6.7, Auto, AirAid Intake, H&S 4" TBE-BlackMaxx-TCM-+Complete EGR Delete, RBP Tailpipe, BrakeMan Brakes, BME EWG, HID's, MagHyTec Diff/Trans, Shibby Boost Tube, Stage 2 Horn, TVD, ISSPro Gauges, Amsoil, Pioneer, Sirius, Rockford 3Sixty.2, RF/MB Quart Mids/Highs, Rockford & Kenwood Amps, ProBox Rocks Dual 10" subs, Hornblaster Train Air Horns, Magnaflow CAT.
azpyroguy is offline
post #2 of 27 (permalink) Old 08-05-2008, 11:22 AM
rufushusky's Avatar
The max for shot bursts is around 1600*, max sustained EGT is about 1250*. As far as boost I am not too familiar with the VGT on the 6.7 but I would say high 30s to low 40s.
2002 Ford F-350 ECLB 7.3 4R100 4X4, 6637 intake, 203* T-stat, 08 diff cover, HPX, Stancor Relay, 6.0 trans cooler
Gone:
04.5 Ram 2500 Reg Cab 48re 205k miles
rufushusky is offline
post #3 of 27 (permalink) Old 08-05-2008, 11:26 AM Thread Starter
azpyroguy's Avatar
Forgot to mention, my EGT sensor is Pre-Turbo.
post #4 of 27 (permalink) Old 08-05-2008, 11:34 AM
Teen wolf's Avatar
Ya, I'm a 5.9 guy but I bet your truck loves you mine sees 1450 for 5 seconds at any grade racing whatever.that is my limit though...
06 black mega 4x Dave's Billet auto shiftenhansed D preditor tuff 5" 37's B special fooler riderites custom airbag muff delete redline catylist, Commander , AR-15..etc...."True Outlaws can survive"
Teen wolf is offline
post #5 of 27 (permalink) Old 08-05-2008, 01:43 PM
MuscleHead's Avatar
Questions:
Considering i never ran mine hard with the emissions intact im not sure but many 6.7 owners have taken it near 1700 degrees for short intervals. I personally have my defuel setting at 1500 degrees. Sorry to break it to you but that DPF back exhaust was a waste of money. You will not see any power,sound, or egt drop from doing it.
2014 3500 Crew Cab DRW LWB 4x4, 4.10 gears,2.5" Rough Country Leveling Kit.
MuscleHead is offline
post #6 of 27 (permalink) Old 08-05-2008, 02:04 PM
LittleOleHotShotter's Avatar
Dont know how you guys are seeing 40 PSI of boost, i max out at 31. But i always have a trailer attatched so maybe thats why. I figure under load i would see more boost. guess not. U guys are also stacking too where as im in tow mode or stock settings
TRUCK IT TRANSPORT
LittleOleHotShotter is offline
post #7 of 27 (permalink) Old 08-05-2008, 04:50 PM
diesel addict
Alls I have seen is 31, I havn't really looked, but a turbo that big and as much fuel as I am pushing, a guy should see a lot higher, must be wastegated, as my 03 w/ a boost fooler would run up to 36. As far as egts go, the regen system runs at around 1400 when driving hills, so I am pretty sure 1500-1600 isn't too bad for it, as long as you arent doing this for like 20 miles. I got rid of my governor w/ the pmt and with my 35's my truck will run almost 140mph, I was defueling at 1650, b/c aluminun starts to melt at around 1700, I wouldn't like to see stuf just turning into a black blob of sh!t in my engine bay
'15 Limited max steel 2500 mega cab: HPP csp5, flopro, 20x9 Hostile Exiles, 295/65R20 Exo Grapplers, AMP steps
highdrum is offline
post #8 of 27 (permalink) Old 08-05-2008, 06:23 PM
MuscleHead's Avatar
What exactly is aluminum on this engine
post #9 of 27 (permalink) Old 08-05-2008, 06:34 PM
avid's Avatar
I've hit 36 or 37 on mine with the PMT set on Extreme. The highest I've seen my EGTS go was 1550*
2007.5 - 2500 Quad Cab, LWB
Smarty, AFE Mega Cannon, ANSA Silverline 5" T304 exhaust, ISSPRO Guages, No EGR, HIDS, SBC3600
avid is offline
post #10 of 27 (permalink) Old 08-05-2008, 09:07 PM
Compcowboy's Avatar
I havent seen over 32 for boost and that was only for a split second. EGTs are ok up to 1600 for short times.
Sold - 07.5 6.7 Big Horn with lots of goodies.
New Project - 84 Chevy CCSB 12v Conversion, G56 w/271 transfer case, Custom 4 link Coil Over Suspension and much more!!!!!
Compcowboy is offline
post #11 of 27 (permalink) Old 08-05-2008, 09:28 PM
MuscleHead's Avatar
I wonder if that intake on yours is helping it spool more? 32 is as high as i have hit and thats on extreme.
post #12 of 27 (permalink) Old 08-05-2008, 09:56 PM
AMC Blastin''s Avatar
I have my settings maxed...and my Turbo has seen 44 psi. But I think my intercooler allows the boost to climb.
ATS TC & Tranny, II 64/71mm Stage 2 VGT Turbo, Stage III CP 3, 130 HP Injectors, ARP Headstuds, S & B Air Intake, Edge w/ Att., MP8, 5" TBE w/ Duel Exhaust, EGR Delete, 4.5" Lift, Banks Intercooler, Fass 150,Qzilla Boost fooler.
AMC Blastin' is offline
The Following User Says Thank You to AMC Blastin' For This Useful Post:
keithb (12-31-2014)
