p106 problem solved, BOO YA! - Dodge Cummins Diesel Forum
post #1 of 15 (permalink) Old 04-29-2013, 10:03 PM Thread Starter
harvestguy2000's Avatar
Be having trouble with the ETC light and code p0106 and going into limp mode under higher turbo boost pressure for about a year now. Replaced the TURBO BOOST SENSOR and problems no more! It's easy to change out just don't buy the part from the dealer. I did and it was $388. I think Geno's Garage online it's under $200. Now its like driving a new pickup, now I'm happy happy happy!
2008 Dodge 2500 Quad Cab, Short Bed, 6 Speed Auto, 4WD, SXT, H-S Performance Stage II 4'' DPF delete, EGR gone, XRT!
harvestguy2000 is offline
post #2 of 15 (permalink) Old 09-03-2013, 05:53 PM
Guest
Guest
Posts: n/a
Where is that located? I am having the exact same problems.
post #3 of 15 (permalink) Old 09-03-2013, 06:35 PM
Guest
Guest
Posts: n/a
its located on the top side of the turbo, has a wire going to it, wire has plastic covering around it. Its held in by a small bolt that you can't see just feel.
post #4 of 15 (permalink) Old 09-04-2013, 12:27 AM
Guest
Guest
Posts: n/a
Do you mean this?<br />
CUMMINS 4032316 TURBO SPEED SENSOR ('07.5-'09, 6.7L)<br />
If your Fourth Generation Dodge Turbo Diesel truck gets a P0106 code or exhibits excessive exhaust smoke and higher exhaust gas temperatures than normal, it may be the turbo speed sensor causing the problem
post #5 of 15 (permalink) Old 09-04-2013, 01:34 AM
Guest
Guest
Posts: n/a
<div style="margin:20px; margin-top:5px; ">
<div class="smallfont" style="margin-bottom:2px">Quote:</div>
<table cellpadding="6" cellspacing="0" border="0" width="100%">
<tr>
<td class="alt2" style="border:1px inset">
<div>
Originally Posted by <strong>harvestguy2000</strong>
<a href="showthread.php?p=6230257#post6230257" rel="nofollow"><img class="inlineimg" src="http://image.autoforums.com/cumminsforum/buttons/viewpost.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Be having trouble with the ETC light and code p0106 and going into limp mode under higher turbo boost pressure for about a year now. Replaced the TURBO BOOST SENSOR and problems no more! It's easy to change out just don't buy the part from the dealer. I did and it was $388. I think Geno's Garage online it's under $200. Now its like driving a new pickup, now I'm happy happy happy!</div>
</td>
</tr>
</table>
</div>Don't you love when you figure out something that plagues you?<br />
<br />
Congrats man, I know that special feeling all too well.
post #6 of 15 (permalink) Old 09-04-2013, 12:21 PM
Guest
Guest
Posts: n/a
yep, that's the problem. Change that sensor out and you'll be trouble free from limp mode and p0106 <img src="images/smilies/smiley_chicken.gif" border="0" alt="" title="chicken" class="inlineimg" />
post #7 of 15 (permalink) Old 09-04-2013, 12:33 PM
Guest
Guest
Posts: n/a
Yep, had mine done under warranty years ago.
post #8 of 15 (permalink) Old 11-01-2013, 08:53 AM
Mr Bojangles's Avatar
Hello:
That sensor Kit number, 4032316 is available on "Peterbiltparts.com" for 153.28 but it's been referred to as "Speed Sensor".
I'm getting code P2579 which is associated with This speed sensor. I'm told by my mechanic that the whole Turbo Charger must be replaced to fix.... others on this forun saying this is not true. One can replace this sensor with Turbo on truck...
"Mr. Guest".... is this true in your experience?
2008 RAM3500-Quad-Auto- 4x4 w/3.73 -long bed, SRWs, Laramie, 115 Gal Aux Tank. Pulled TT across USA, E to W, and Key west twice each, 60K miles of trips with Ram3500. ALL GOOD!
Mr Bojangles is offline
post #9 of 15 (permalink) Old 11-01-2013, 11:08 AM
xcc_rider's Avatar
Mine was done under warranty, in the truck in less than 30 min including car wash.
2007.5 Black Ram 2500 MC SLT 6.7, 2wd, 68rfe, 3.73 diff
Edge CTS, SmartyJr tuned, PML xtra deep trans pan and 2 add on fuel filters
(delete parts are no longer in the garage)
xcc_rider is offline
post #10 of 15 (permalink) Old 12-02-2013, 11:52 AM
Kaistie's Avatar
I am also now in the middle of tracking down this darn P0106 gremlin. I've got a few additional issues however. First, truck info: 2008 4x4 fully deleted 5" TBE, CAI, CCV filter deleted, H&S XRT Pro wild tune with transmission tune, Edge Juice still installed but set to stock, Edge CTS monitor, fully deleted at 30K and now at 99K. No problems to speak of since deleting.
So about a month ago I towed a 10,000 load up to Northern AZ with several long steep climbs. On the first big climb I was holding steady at 65mph with no issues when the truck just fell on its face. The MIL and CEL came on and I pulled over. After shutting down and restarting, I was back on my way. I was fine the rest of the trip.
When I got home I searched and found several threads about this P0106 issue and did the following: Cleaned the MAP, MAF and IAT sensors and harnesses with MAF electronic cleaner, cleaned air filter, checked fuses and checked for leaks. No further issues over the next couple weeks daily driving it (No towing).
Fast forward to this most recent weekend and I was headed North again with the same load. This time however it tripped 4 times over the course of 60 miles on the way up. I stopped, shut down and restarted each time. On the way back down the mountain however is where I experienced something weird. I had the EB engaged when it all of a sudden changed both the way it normally sounds and the braking force. It sounded like it was barely engaging, but definitely was engaging. I tried downshifting, playing with the button and everything in between. At one point it came one normally for about 3 seconds and then got quiet and produced very minimal braking power, but I could still faintly hear it whistling. Once I made it down the mountain and on fairly flat roads it seemed to begin working again. Also, my CTS reads the following "Manifold Absolute Pressure Sensor Performance +B4687". Does the B4687 mean anything? I can't find info on it?
So, what i've found is that both the P0106 and Exhaust Brake issues happened while towing. When daily driving I have no issues. In fact, on the way to work this morning the EB worked normally with no issues.
Based on all the threads I've read, I am gretting ready to purchase a new turbo speed sensor, especially since I've noticed an EB issue. Am I headed in the right direction?
One other piece of info; While cleaning my MAF sensor I noticed that it did not have the two wire resistor like every other MAF sensor I've seen. I tried searching for it and found half the pictures I've seen show the resistor, and half do not?? If that little resistor came off, it might explain the EB issue since it would have been sucked into the compressor and gone through the motor Anyway, here is the picture I took of my MAF.
Thoughts??
1)2000 Tacoma Crawler. pics here=
2)2008
Kaistie is offline
post #11 of 15 (permalink) Old 07-27-2014, 10:22 AM
What did we find out? I'm having these problems also.
newt014 is offline
post #12 of 15 (permalink) Old 07-27-2014, 11:01 AM
Snofarmer's Avatar
Yes, they all have that pancake resistor/capacitor in the MAF.
If it's gone or got broke from cleaning it needs to be replaced.
next, before comdeming parts take a look at the pulse line that goes from the turbo to a block with a sensor in it, that is mounted ontop of a coolent fitting/bock up of the front of the engine.
remove and clean it out.
just a idea.
Snofarmer is offline
