Red lightning bolt is on? - Dodge Cummins Diesel Forum
post #1 of 24 (permalink) Old 04-03-2013, 11:27 AM Thread Starter
GCH
It's been coming on while driving some and have talked with other owners who have seen theirs come on but everything works fine. What it the light and what would be the problem?
Thanks G
New Truck- 2014 3500 MC DRW Laramie 6.7 Aisin B&W companion 24K LineX Deep Cherry
Sold- 07.5 3500 MC DRW 6.7 auto 6 speed
GCH is offline
post #2 of 24 (permalink) Old 04-03-2013, 03:35 PM
I have the same problem and been wondering what's causing it. Subscribed
bignastydodge is offline
post #3 of 24 (permalink) Old 04-03-2013, 03:44 PM
08 Cummins
KhakiCummins's Avatar
The lightning bolt is typically related to the throttle valve. What modifications have you done to your truck?
Duane
2008 Ram 3500 QuadCab
Hamilton 103# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
2014 Jetta TDI 6 SPD Manual
KhakiCummins is offline
post #4 of 24 (permalink) Old 04-03-2013, 04:09 PM
Mine got full deletes included the throttle valve, and running efi for tuning.
post #5 of 24 (permalink) Old 04-03-2013, 04:14 PM Thread Starter
GCH
Mine has the DPF delete and the EGR unplugged with minimax tuner and Trans software.
Could this be a problem, it seams to run just fine?
GCH is offline
post #6 of 24 (permalink) Old 04-03-2013, 06:33 PM
mr. ed's Avatar
When I had that problem it turned out to be a bad battery. You should have them load tested. Also, be sure connections are good. I'll bet that's your problem since everything else appears to be working OK.
2007.5 RAM 3500/6.7/G56/4WD/SB/SRW/mineral gray/Big Horn edition/bone stock
2007 Hitchhiker 29.5 LKTG fifth wheel
mr. ed is offline
post #7 of 24 (permalink) Old 04-05-2013, 10:26 PM
scoobert's Avatar
i was losing my alternator when mine came on. also had it come on, when an injector fried open.
cummins all goings, yachting now
scoobert is offline
post #8 of 24 (permalink) Old 04-05-2013, 10:47 PM
Peenutt's Avatar
I was going through the same issue with my rig, but my voltage would stay at only 11.3 or less. Here is what fixed my issue. All terminals cleaned and tight, also
Originally Posted by dozer12216 View Post
Another wierd possibility. Over charged memory in computer.. With ignition key in pocket. Take ALL battery cables loose and away from their terminals. Now hold a positive cable against it's negative brother for 30 seconds or so. This will delete all stored memories (bad ones especially). Yes you lose radio memories also. Reinstall all cables before removing keys from pocket.
After i did the battery trick i have been up and running like a champ. Above quote was from a thread i had made about odd voltage issue. Hope this helps you out also
08 3500HD Big Horn, Revmax built Trans. S&B CAI, Black Maxx W/ OD software
AFE 4" TBE, Studded an gutted.
Peenutt is offline
post #9 of 24 (permalink) Old 04-06-2013, 10:48 AM
torquemada's Avatar
Battery issue most likely. Replace in pairs.
Sent from my iPad using Tapatalk
2008 Dodge Ram 2500 6.7L - S&B CAI, Shibby Stage 2 w/TV delete, EGR and DPF vanished, muffler delete, Black Maxx, TCM tune from MHP. 450 hp 950 lb.ft on the dyno. Check my YouTube page for the video.
torquemada is offline
post #10 of 24 (permalink) Old 04-06-2013, 12:53 PM
stanley91's Avatar
Was some bad wires for the APPS when I had the lightning bolt.
Sent from AutoGuide.com App
2007.5 Ram 2500 6.7L, Mini Maxx, overdrive tune, S&B intake, deletes, 5" Flopro TBE, 5" Roughcountry suspension lift, 17" Mickey Thompson classics, wrapped in 35/12.50/17 Nitto Trail Grapplers!
stanley91 is offline
post #11 of 24 (permalink) Old 04-06-2013, 11:22 PM
airborneRGR's Avatar
iTrader Score: 6 reviews
Make sure your battery cables are tight
2013-Megacab Laramie, auto, deleted 2012-Crew Cab-Sold 2013-Megacab-Sold 2008Quad Cab-Sold 2008 Megacab-Sold
airborneRGR is offline
post #12 of 24 (permalink) Old 04-06-2013, 11:55 PM
coorsman2005's Avatar
when mine has came on my truck goes to limp mode the exhaust pressure sensor will cause that light as well found that out last wkd its not just electrical good luck
2008 6.7 cummins,full deletes,efi live,silver 66 turbo,valair dd nv5600 conversion, 5" exhaust 6"lift 37x13.50 toyo mt's, 2000 dodge 1/2 ton 4x4 12v conversion (mostly stock) g56 conversion.
coorsman2005 is offline
