68rfe valve body change - Dodge Cummins Diesel Forum
 1Likes
post #1 of 17 (permalink) Old 04-02-2013, 09:39 PM Thread Starter
I ordered the hd/towing valve body from REVMAX I have changed trans filters in the past, but am wondering if changing the valve body is DIY kind of thing?
don't really want to pay $250-$300 labor if I can do it myself. Ihear it is fairly easy. Any advice? THANKS
MPC 1
2007.5, 3500,6.7, 6sp auto,Quadcab,LB,DRW,4X4,K&N,SPRAY BEDLINER.2006 ELITE 3HORSE, 12' LIVINGQUARTERS TRAILER(15,000#),MHP TCM, Hypertech max energy,
MPC 1 is offline
post #2 of 17 (permalink) Old 04-03-2013, 06:32 AM
Military Veteran
Cummins_stalker's Avatar
iTrader Score: 7 reviews
I personally have not replaced a VB but watch this video.
Based on your signature it appears that the only modification done to your stock transmission is a TCM from MHP. Is that correct?
2008 6.7 2500 QCSB PDD 47RE/DPC 4D FAT SHAFT/PCS/SUNCOAST VB/EFI/FMW S480 OVER GT55/STAINLESS T6/DUAL CP3S II 120% & DMAX/ADx2/BBI STAGE 4/B&B SIDE INTAKE/CARRILLOS/BUILT HEAD/ARP 625S/MAXSPOOL CAM/.020 MAHLE PISTONS/GIRDLE/FLUIDAMPR/CALTRACS/HURST QUARTER STICK....DAILY DRIVER
Cummins_stalker is offline
The Following User Says Thank You to Cummins_stalker For This Useful Post:
r1bill (03-25-2017)
post #3 of 17 (permalink) Old 04-03-2013, 07:59 AM
TECH SPECIALIST
Yes, replacing the VB is pretty simple. Just make SURE you get the slot in the manual code plate (the part on the VB that moves back and forth when you move the shift lever) correctly aligned with the pin on the manual lever (inside the trans) when you install the new VB. Put the shift lever in PARK before starting. Then on the new VB, slide the code plate all the way rearward, so the detent roller is up against the vertical leg on the plate (this is the PARK position) before installing it, and you should be good.
It can be a little tricky to get the main wiring harness disconnected from the VB (connector on the solenoid module, on top of the VB). The harness connector has a locking lever and a secondary latch. The connector on the solenoid module is square and has two small round posts sticking out of opposite sides of the connector (one towards the front of the vehicle, one towards the rear). The locking lever on the harness (which is probably gray in color) wraps around three sides of the connector. The latch is on the driver's side. The two sides that wrap around have slots that engage with the two posts on the solenoid connector. When the connector is unplugged, the locking lever (latch side) is down (toward the open end of the harness). When you plug it into the trans, the slots engage with the posts. Then, you push the locking lever latch bar up, which rotates the locking lever and clamps the harness connector down into the trans connector (by grabbing and pulling on those posts). I know this is hard to visualize... sorry but I don't have a picture.
To disconnect the harness, you first need to release the secondary lock. This is typically a red plastic piece (on the driver's side of the connector, just below the locking lever latch bar, which will be at the TOP of the connector when it's locked). You'll need to slide this red secondary lock either up or down (I'm not sure which, probably down but I'm not positive) before you can unlock the lever. Once that's done, reach up above and behind the center of the locking lever. The latch that holds the locking lever is just behind the face of the center of the locking lever (there's about 1/4 inch space between them). Put your finger behind the face of the locking lever, and push it and the latch APART. You need to push the latch (the piece just behind the top of the locking lever) in, towards the transmission (away from the locking lever) in order to release it. Once the locking lever pops free, rotate it down as you lift the harness up and off.
When you go to re-connect it, make sure the locking lever is DOWN (towards the open end of the harness connector) so it will engage the posts on the trans connector, then plug it in and rotate the locking lever up til it latches. Then slide the secondary lock into position to retain it.
Good luck!
TransEngineer is offline
The Following 4 Users Say Thank You to TransEngineer For This Useful Post:
imkindofabigdeal (11-20-2016), MPC 1 (04-03-2013), nbk9nbk (11-18-2013), r1bill (03-25-2017)
post #4 of 17 (permalink) Old 04-03-2013, 10:39 AM Thread Starter
YES that is the only trans. upgrade.
MPC 1
MPC 1 is offline
post #5 of 17 (permalink) Old 04-03-2013, 10:44 AM
Military Veteran
How do you plan on wiring it up? Toggle switch or how do you plan on activating it/locking it up? Thanks
post #6 of 17 (permalink) Old 04-04-2013, 10:36 AM Thread Starter
I'm putting in the HD/TOWING VB not the lock-up. sorry for not giving more info.
Trans Eng. do you have to do a learn when replacing the VB?
Thanks so much for your help.
MPC 1
MPC 1 is offline
post #7 of 17 (permalink) Old 04-04-2013, 10:55 AM
TECH SPECIALIST
Yes, technically you should run the QuickLearn procedure (using a scan tool) after replacing the VB. If you can't do that, then I'd advise driving it gently for the first few hundred miles.
post #8 of 17 (permalink) Old 04-13-2013, 05:33 PM
Valve body change
Can this be done with the trans still in the truck?
davestrim is offline
post #9 of 17 (permalink) Old 04-13-2013, 08:22 PM
7492's Avatar
68RFE Teardown & inspection - YouTube
At least this one is in English.
r1bill likes this.
07 Megacab 3500 4x4 6.7Liter 68RFE 22 MPG highway.
2011 Durango Hemi Loaded
09 Freightliner M2 33k GVW ISC 360/1050 RFO9210
7492 is offline
post #10 of 17 (permalink) Old 04-14-2013, 05:46 PM
rjp
WWW.SuncoastConverters.co
rjp's Avatar
OMG i laughed so hard at this. Is that you and your paw bro?
rjp is offline
post #11 of 17 (permalink) Old 04-14-2013, 07:48 PM
7492's Avatar
Why are you laughing?
7492 is offline
post #12 of 17 (permalink) Old 04-14-2013, 07:59 PM
rjp
rjp's Avatar
It just fits your key board personality to a "T". I seriously had to turn it off, the words were killing me, as well as my side.
That sit was funny, i don't care what anybody says. Hell, the dude in the video even had to try and keep his composure. He was wanting to laugh sooo bad.
rjp is offline
The Following User Says Thank You to rjp For This Useful Post:
SotallyTober57 (03-03-2014)
