"WEIRD NOISE" when in reverse - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 07.5 - 09 6.7 Liter Cummins > 07.5 - 09 3rd Gen 6.7L Powertrain
Old 07-17-2012, 09:44 PM   #1 (permalink)
dodgethebullet88's Avatar
So never ever heard anything like this.. Truck is making a weird noise.. I wish this place could include sound bite clips, but other than posting to you tube i wouldnt know what else to do, other than try and describe best as possible..
It is a sqeaking noise not like clank clank, not metal on metal sound, sounds kinda like brakes do when you hold them under pressure on a hill and let off to roll that initial sound at let off, is kinda what it is.. But cant be brake related.. Next weird thing is this is only happening in reverse.. Reverse only, i was thinking universal joint but all looks good and common wisdom says if it does it in reverse it should do the same in forward and also in neutral.. But it only does it in reverse.. It the same noise over and over.. I got under the truck and had some one reverse the truck while i tried to listen and it sounds kinda like in the drive shaft but why only in reverse and what is this noise and cant pin point it.. It is very noticeable and not a slight or fant sound..
Dont know anyone ever had anything like it or not..
07.5' 2500 Auto 6-Spd Quad Cab Inferno Red Big Horn Edition 4wd. Toyo Open Country M/T's on 18" Chrome Rockstars, Black Maxx w/ OD Software AFE Stage II CAI, 5" TBE FloPro w/o Muffler , Egr Removed also cooler has been deleted and not plug... Smoke switch
dodgethebullet88 is offline   Reply With Quote
Old 07-17-2012, 09:49 PM   #2 (permalink)
CHUGGINSMOKE05's Avatar
Same issue with my '79 F-100 when I drove it everyday. Noticed it while backing up at a gas pump one day. It was the rear u joint in mine.
If you have a Photobucket account you can post vids that way
05 Laramie Dually Tuckin 22's Smarty|Hellman|Flux|DTT|Sonnax|Nitto|Autometer|FTI |Crazy Carl's
CHUGGINSMOKE05 is offline   Reply With Quote
Old 07-17-2012, 10:03 PM   #3 (permalink)
u-joint, my experience has always had it start with the noise in reverse. after out driving, get under neath and feel both. the one that is the warmest, is the one going. or just keep going, it'll get worse and you'll know exactly which one.
2007.5 2500, 6.7 liter cummins, Smarty S67, FPE Boost Controller, HE351VE w/ 60/83 comp wheel, Air Dog FP-150, 5" TBE
1995 Chevy w/t, 4.3l V-6, 5 speed manual sold
bloyet03 is offline   Reply With Quote
The Following User Says Thank You to bloyet03 For This Useful Post:
dodgethebullet88 (07-18-2012)
Old 07-18-2012, 09:04 PM   #4 (permalink)
Thanks, yea i just never heard anything like it.. I am going to try to tell which one it is indeed, by using your described method. Never heard of that but makes total sense however tho..
Thanks!
Old 02-25-2013, 09:45 PM   #5 (permalink)
007MegaRam's Avatar
Whinning noise only when is reverse...
Did you figure out what it is brother?
My '07 is doing the same thing now, sounds almost like the power steering pump, but it only happens when the tranny's in reverse....
Ford for work, Dodge for everything else!
2007.5 3500 Mega Cab Dually, H&S Tuner & deletes,XX-Fuel, DSS, no CCV filter, PCV blocked&dropped, FireStones sand balanced Blaupunkt Navi n' camera soon.
007MegaRam is offline   Reply With Quote
Old 02-27-2013, 08:40 AM   #6 (permalink)
smokeuout09's Avatar
it was the very back u joint. THe one at the yoke on the rear end. Its fun to put in lol
2008 Dodge 2500 6.7 AFE Stage 2. 4in Turbo Back. H&S Mini Maxx // 2004 F-350 4x4 6.0 flatbed. // 2002 F-250 4x4 7.3 CC.slightly moded // 2001 F-350 6 speed. slightly moded
smokeuout09 is offline   Reply With Quote
Old 03-02-2013, 10:21 AM   #7 (permalink)
007MegaRam's Avatar
Thanks brother, I was worried it was the transmission or something
