Dual remote oil filter kit - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 04-16-2012, 01:48 PM Thread Starter
Cummins Theorist
Anybody running one of these? I really like the idea of extended oil change intervals, relocation of mounting position and the better micron filtration...Dual Remote Filtration System Mounting Kit BMK23 by Amsoil
EFILive by Dave Matthews, Suncoast M3GA 68, Stainless Diesel 2nd Gen BW467.7 swap, Industrial Injection 60hp Dragon Fly Injectors, Arson IV injection pump, Yukon Free Spin Kit w/ Hardcore Hubs, Dyno'd @ 599.77hp and 1099.77ft lb...non loading dyno
M*A*S*H is offline
The Following 2 Users Say Thank You to M*A*S*H For This Useful Post:
cummins4g63 (05-06-2012), Duluth Diesel (05-06-2012)
post #2 of 9 (permalink) Old 05-06-2012, 11:34 AM
cummins4g63's Avatar
Iam also thinking about it. Anyone with pics would be even better
2011 RAM 3500 MC srw 68Rfe laramie 6.7 line x, afe stage 2 Cai, Rancho rs9000xl,5inch turbo-back w/ muffler, mini maxx w/ overdrive, egr delete (full), GDP big fuel line kit. Amsoil By-Pass/full flow and CI-4, B&W turnover,Mag-Hytec 68rfe/rear diff pan/cover
cummins4g63 is offline
post #3 of 9 (permalink) Old 05-06-2012, 12:00 PM
Duluth Diesel's Avatar
The BMK-21 is the recommended bypass kit for these trucks currently. AMSOIL discontinued the BMK-25 kit, but I'm checking in to what parts would be necessary to make a dual kit that would work like the BMK-25.
Bypass filtration is a huge benefit to diesel engines, especially modified engines that soot load their oil at rates much quicker than bone stock engines. Standard Mopar/Wix cellulose filters at 35 microns. Fleetguard Stratapore filters are 25 microns. AMSOIL EaO full flow filters are 15 microns. AMSOIL bypass filters are rated at 2.00 microns. All micron ratings are noted at absolute efficiency (99.97%) rather than nominal (50%). Watch out for manufacturers that give you finer micron ratings but fail to inform you that they are nominal, not absolute. That makes a huge difference.
If anyone wants quotes on AMSOIL systems, feel free to PM me since I can't post pricing on the open forum.
-Chuck
Duluth Diesel is offline
The Following 2 Users Say Thank You to Duluth Diesel For This Useful Post:
Doug B (05-11-2012), M*A*S*H (05-06-2012)
post #4 of 9 (permalink) Old 05-13-2012, 01:07 PM
Amsoil Bypass Filter Installs
Here are a couple previous posts with info that may be helpful
http://www.cumminsforum.com/forum/6-...s-bracket.html
http://www.cumminsforum.com/forum/6-...lots-pics.html
2007.5 2500 Inferno 6.7 4x4, Smarty JR ME, Sinister EGR/Cooler removal kit, downpipe/DPF Delete, Custom Diesel steering brace
"Land of the free because of the brave!"
thebolt is offline
post #5 of 9 (permalink) Old 08-02-2012, 02:34 AM
Pellerin's Avatar
Hey guys. I really need a remote oil filter for my Cummins. With the V-Mac compressor mounted under the front of the engine, the oil filter is a pain to get at.
It takes me an hour to change oil in my rig. Mounting it behind the front bumper would be sweet.
Sent from my Autoguide iPhone app
Pellerin is offline
post #6 of 9 (permalink) Old 08-02-2012, 03:08 PM
My filter farm. Oil on right, Fuel separator and filter on left.
2007 2500 Mega 6.7L EFI Live, ATS Stage 2 68RFE w/ CoPilot, MHP/B&G TCM Mod Tune, 2 WD w/ NV271 Manual Transfer Case, Edge JWA Gauges, Nitto Terra Grappler 285 70 17, Fixed the DPF, NOX and EGR, much better now, AFE Stage 2 Pro Dry, Shibby Stage one intake, BM EWG, Autometer 7504/7505/7506 Boost gauges, Maxxbrake controller, Rancho 9000XL with MyRide, Hellwig air bags, A wealth of stealth.
2500MegaDiesel is offline
post #7 of 9 (permalink) Old 08-02-2012, 09:35 PM
OilFun's Avatar
2500mega that's a sick setup. Chuck is a good guy, he set me straight. I went with the bmk21 as its recommended over the dual bypass.. I followed this guys right up, easy and only required a piece of metal and some bolts. http://www.amsoil.com/bypassfilters/...Ram_Uzunis.pdf
'09 2500 Laramie Mega G56 (retired)
'15 2500 Limited Mega 68RFE
OilFun is offline
post #8 of 9 (permalink) Old 08-02-2012, 10:01 PM
huntforfunnfood's Avatar
ah....wouldn't those fuel filters work better if you had ran the fuel lines to them
2009 dodge 6.7 cummins crew cab 2500 big horn/ 4x4/ auto / smarty jr / dfp deletes / egr unpluged / 285-65-18 nitto tarra grapplers / 18"x9 MB vision v-drives / debadged
huntforfunnfood is offline
post #9 of 9 (permalink) Old 08-02-2012, 11:10 PM
VP Moderator
dozer12216's Avatar
my take on add on bypass systems.
And how many more miles will this setup get before it wears out? I don't believe a bypass will get you any more miles, regardless of claims of greatness made.
What benefit is it, when one the hoses takes a crap and dumps oil. Besides the return in filler cap looks like xxxx (use your own explitive)..
Engines don't fail from oil and filtering problems when changed properlly. JMHO of course.
dozer12216 is offline
