Found grease point 6.7L driveshaft, but now what to do? - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 07.5 - 09 6.7 Liter Cummins > 07.5 - 09 3rd Gen 6.7L Powertrain
Old 03-18-2012, 08:52 PM   #1 (permalink)
I finally found the grease point for the front driveshaft on my 2011 6.7L, and I bought the 1.5-inch needle nose adapter for my grease gun. Tried spooging the grease in there with the needle nose, but when I pull the needle nose adapter away, all I see is grease around the fitting. It's as if the grease is getting blown outside, not into, the fitting.
How are these fittings supposed to work? Looks like there's a little ball at the center of the fitting -- should I expect to push the ball inward with brute force, and then pump the grease? Or does the pressure of the grease force the ball inward on its own, allowing grease to get past it? Is there a spring behind the ball? Should I break it free first by pushing it inward with a (very strong) needle?
Why the hell couldn't they use a zerk. I'm 500 miles overdue and worrying that the front driveshaft isn't properly lubed.
Sold: 2011 6.7L 2500 SLT 4WD Crew auto HO (68RFE), +XRTPro (stock HP, OD trans tune) -EGR/cooler -DPF -badges
amp2005red is offline   Reply With Quote
Old 03-18-2012, 09:02 PM   #2 (permalink)
Motorboat's Avatar
You need a needle tip for your greasegun.
'97 3500. 4X4 3:55s, built auto, vb and triple disc tc w/lockup. Boost, trans, pyro and F/P. Silicone hoses and boots. Icebox intake, 4" Diamondeye. 10 plate, 330s, 60# springs, 4GSK, Pacbrake. Mag trans and diff covers. Firestone Bags and 51 Gal. transfer tank.
Motorboat is offline   Reply With Quote
Old 03-18-2012, 09:07 PM   #3 (permalink)
Yes - already done - now I hate to sound like an idiot but forgive me... I mashed the needle nose adapter snug up against the fitting and squeezed the pistol-grip trigger, and when I pull it away, most of the grease (all? not sure) is coming out around the fitting... not into it. It's almost as if the pressure of the grease isn't forcing the little ball back and allowing the grease to go inside the fitting, so the only other place for it to go is around (the outside of) the fitting.
Sorry for my ignorance... I know this should be simple.
Old 03-18-2012, 09:24 PM   #4 (permalink)
Did you jack up the front passenger side tire so you can turn the fitting at the best possible angle. Go at it from the passenger tire side in front of the cross member. I haven't tried yet as I'm waiting on my needle to come in the mail, so hope this helps.
2008 Ram 2500 6.7L, 4X4, QC, 68RFE / Smarty J-67 28ME / Sinister EGR Cooler delete / Diamond Eye DPF delete / Dynatrac Ball joints / Carli U-joints / Sinister Steering Box Stabilizer
qmrichardson is offline   Reply With Quote
Old 03-18-2012, 10:41 PM   #5 (permalink)
DieselWorkin's Avatar
I don't exactly how the fitting works, but the needle does kind of click in there. NOT with force or an actual click, but I just mean you can feel when it's where it's suppose to be. When it's connected right ALL the grease will go in. If any is not going in I don't think any is going in at all...
YouTube.com/DieselWorkin
2010 Ram 3500 SLT RC/LB/DRW 6.7L 4x4 G56/Manual 3.42
4" DP To 5" Straight Pipe To 6" Tip Side Exit / Airaid Intake / H&S MM
DieselWorkin is offline   Reply With Quote
Old 03-18-2012, 10:48 PM   #6 (permalink)
cntryby's Avatar
The needle we're talking about looks like a syringe needle is that what you're using or are you using the tapered pointed tip?
The needle actually slides in the hole.
08, 3500, mega, 4X4, Passenger Industries manifold & tube, sub-zero intercooler, Flo-pro 5" SS TBE, Hot Damn 175 ATT, ARP 2000's, Nitto Terra Grapplers, SRT hood, Amp power steps, B&W turnover & Tow n Stow, line-xtra, limo tint... great big nuts.
cntryby is offline   Reply With Quote
Old 03-18-2012, 11:13 PM   #7 (permalink)
BILLS06's Avatar
Got two types
Need to use the top one.
06 QCSB SLT
Headlight Eyelids Fluidampr EZ Down ATS Converter Fog Lamps Aero Turbine Muffler Reflex Bed Liner
BILLS06 is offline   Reply With Quote
The Following User Says Thank You to BILLS06 For This Useful Post:
2012 RAM 3500 (03-19-2012)
Old 03-18-2012, 11:35 PM   #8 (permalink)
Originally Posted by BILLS06 View Post
Got two types
Did you post those backwards? I use the bottom one, I don't see how the other one would work...
The Following User Says Thank You to DieselWorkin For This Useful Post:
2012 RAM 3500 (08-18-2012)
Old 03-18-2012, 11:41 PM   #9 (permalink)
insane3639's Avatar
iTrader Score: 5 reviews
you just attach it to the gun like normal no having to make special adapters
2007.5 SOLD.
2005 AUTO | 5"TBE | S&B CAI | SMARTY SR
insane3639 is offline   Reply With Quote
Old 03-19-2012, 07:59 AM   #10 (permalink)
Glad to Be Here
2012 RAM 3500's Avatar
Where did you find that one?
2012 Ram 3500, G56, 4 x 4. Stock.
2012 RAM 3500 is offline   Reply With Quote
Old 03-19-2012, 10:21 AM   #11 (permalink)
Snofarmer's Avatar
I have both but I use the one pictured on the bottom . (bigger of the 2)
I don't see the syringe needle supplying much grease or working very well?
All you do is hold it firmly in place and give your grease gun a couple of pumps.
If you haven't done this before you may need to clean the grease point first.
SnoTo Cheap for a brag line~
Snofarmer is offline   Reply With Quote
Old 03-19-2012, 12:26 PM   #12 (permalink)
I use the bottom one also. I use about a 4" one that I bent into a 45 degree angle. Much easier to get it onto the fitting at the right angle.
2008 6.7 Quad cab SB, G56, 3.73, black, Edge Insight, 285-70/17 BFG, otherwise all stock.
2000rpm is offline   Reply With Quote
