2 micron Fuel filter - Dodge Cummins Diesel Forum
post #1 of 28 (permalink) Old 01-25-2012, 07:31 PM Thread Starter
cpobst's Avatar
I have read threads on fuel filters on here but still have a few unanswered questions. I figure that a 2 micron system should be my next investment to protect my truck (then possibly a bypass system). I was looking at the Cummins Cat fuel filter kit. It looks easy to install although I cannot find any instructions. I would like to stay away from dropping the tank if possible. Any thoughts on this kit or should I get one with a water separator? Do I still keep my factory filter in place with these kits?
Cummins CAT Fuel Filter Kit
2012 F150 Ecoboost
SOLD-2011.5 3500 SRW Mega HO 4wd Big Horn
Mini-Maxx w/ OD software, Flo-Pro DPF delete and downpipe, HIDs all around, Sinister EGR/Cooler delete,Console shift mod, GDP ladder bars
cpobst is offline
post #2 of 28 (permalink) Old 01-25-2012, 07:45 PM
Renagade69's Avatar
Those people ripped me off. My kit came incomplete and they will not return my calls or e-mails. They only list it good for the 5.9 also. The mounting will not work anywhere for me. There is a cross member in the way of where its suppose to go on my rig. I can not try though because its incomplete. I am currently in Pay Pal resolution with them.
I am going to get it from here when I get my money back from them,
http://www.vulcanperformance.com/VP-...tems-s/307.htm
2008 2500 Laramie Shortie Quad Cab Automatic Diesel - Smarty JR ME, H&S EGR/Cooler Delete
Renagade69 is offline
The Following 3 Users Say Thank You to Renagade69 For This Useful Post:
cpobst (01-25-2012), Delmar (07-09-2012), ZOP (01-26-2012)
post #3 of 28 (permalink) Old 01-25-2012, 08:20 PM Thread Starter
cpobst's Avatar
Good to know
2012 F150 Ecoboost
cpobst is offline
post #4 of 28 (permalink) Old 01-25-2012, 08:30 PM
TurboDiesel7's Avatar
You want a good water seperator too
08 2500 6.7 68rfe 4x4 efi autocal from starlite carli backcountry
TurboDiesel7 is offline
post #5 of 28 (permalink) Old 01-25-2012, 08:49 PM Thread Starter
cpobst's Avatar
VP Max Filter Systems
That kit looks good with the water separator. It is cheaper also. I guess I will climb underneath when the rain stops and figure out where to mount it so I know what fittings to get. I guess you still need to find lines with that kit right?
2012 F150 Ecoboost
cpobst is offline
post #6 of 28 (permalink) Old 01-25-2012, 08:52 PM
Glad to Be Here
2012 RAM 3500's Avatar
can you not buy the parts and "kit" it yourself? just asking.....
2012 Ram 3500, G56, 4 x 4. Stock. SOLD.
2012 RAM 3500 is offline
post #7 of 28 (permalink) Old 01-25-2012, 08:54 PM
Renagade69's Avatar
The line to connect to is the large line on the top that is 3/8. There is a bolt under the rear seat that can be removed and replaced with a longer one and nut to mount an angle bracket to. I noticed a few other places also. You can call them and they will make up the fittings and hose for you once you get an idea where you are mounting it.
post #8 of 28 (permalink) Old 01-25-2012, 08:55 PM
Glad to Be Here
That vp max kit is nice. I see what I'm getting next!
post #9 of 28 (permalink) Old 01-25-2012, 08:57 PM
Renagade69's Avatar
Yes. I priced those individual parts out and they are not cheap and I did not have the time. I wanted a bolt on kit and got hosed. lol.
post #10 of 28 (permalink) Old 01-25-2012, 09:13 PM
Bad Moon's Avatar
I just order the Baldwin bases, water separator, 2 micron filter and the necessary fittings for a total of $130. Easy enough to make the bracket and follow mounting location instructions found on the XX-fuel web page.
Heck of a lot better than $299
Bad Moon is offline
post #11 of 28 (permalink) Old 01-25-2012, 09:17 PM
cummins98kid's Avatar
for the guys that have a stock fuel pump. how are you installing these filter heads with the stock fuel lines? is there some special fittings to buy or are you replacing all the metal fuel lines with rubber lines? i just wanna figure out how to plumb in the filter head with the stock metal fuel line.
2014 cclb 3500 srw laramie past 2012 mega G56 laramie
2006 qcsb g56, 2001 rclb nv5600, 1998.5 qcsb nv4500
cummins98kid is offline
post #12 of 28 (permalink) Old 01-25-2012, 09:19 PM Thread Starter
cpobst's Avatar
I too would prefer a bolt on kit considering I would be doing this on a Saturday and most likely would not have the parts I need and the decent parts store is closed on Sunday.
2012 F150 Ecoboost
cpobst is offline
