Transmission rebuild cost? - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 01-11-2012, 10:53 PM Thread Starter
Transmission just went out today (68rfe). What are the average costs for a rebuild with r and r of the transmission? I don't need it to hold any additional power over stock.
Iron Man is offline
post #2 of 3 (permalink) Old 01-13-2012, 08:04 AM
TECH SPECIALIST
It depends on what exactly has failed. How many miles on the trans?
If all you have is an input clutch failure (like the OD clutch, the typical weak link), then an input clutch kit (which includes the UD, OD, and Reverse clutch packs) lists for $209 from Mopar. You would also need a new pump cover ($12.50) since the old one is typically damaged when they remove it. You'll probably need maybe 12 quarts of ATF+4, which runs $5.15 per quart in bulk. At high mileage (on a 2009 or earlier truck) you may want to replace the valve body assy - that would cost $463 list from Mopar. If there are other damaged parts, you'll need to replace them. With a bad OD clutch, you can sometimes need a new pressure plate (usually $26.45) or reaction plate ($14.50). If you're having line pressure issues, you may need a new pump assy, which is $489.
The big kicker, of course, is labor. Pulling the trans, tearing it down, and reinstalling it takes about 7 hours per our warranty labor tables, but they often understate the actual time needed, so I'd figure on 10-12 hours. Might be best to call a few shops for an estimate on the labor.
Do you have any fault codes? Can you explain in more detail exactly what your trans did (or is doing, or ISN'T doing)? That might help me make a better guess at what you might need.
TransEngineer is offline
post #3 of 3 (permalink) Old 01-13-2012, 04:41 PM
Rgrgoog's Avatar
Sorry to hear the bad news but if it were me in your shoes this would be a perfect time to upgrade some parts since they are going to have it out anyhow.
2014 CTD 2500 Laramie Longhorn,BDS lift with the Fox shocks and Dual Fox steering stabilizers, 20"x10" Hostile Chrome Hostages with 355/60/R20 Falken ATS ,Edge JWA, 30" Rigid light, Amp steps, BDS Throttle Sensitivity Booster, AFE intake
Rgrgoog is offline
