Coolant leak??? - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 11-01-2011, 11:42 PM Thread Starter
08cummins97's Avatar
Coolant leak???
So I just bought an 08 and was underneath it yesterday on the carport and noticed what looked to be a small coolant leak under the ac compressor on the passenger side of the motor. It left a spot smaller than a baseball on the concrete so I checked the radiator and it was full as well as the overflow. Where could it be coming from on that side? I looked all around the head for an external leak and it's all dry and the engine runs right under the 200 mark. Any ideas or suggestions?? Thanks guys
08 reg cab 4x4 dually 6spd 4.10s white - sinister egr/cooler delete Xrt pro on wild autometer exh boost and rp gauges thuren 3inch coils adj track bar sway bar end links and overland shocks flo pro tb 5" to 7" tip
97 reg cab 3500 dually 5spd 4x4 slt 4.10s - autometer boost and exh temp laser cut dvs and holders oversized inj lines 150s raptor pump fluid damper colt cam stage 3 oringed and studded head 110lb valve springs 3850 sbdd 66/14/72 over s475 snow performance water meth 4inch to twin 8inch turn out stacks on cm skirted bed 1450 yolk and ujoints with ladder bars 058 eagle alloy dually wheels awaiting first start up after twins
08cummins97 is offline
post #2 of 10 (permalink) Old 11-01-2011, 11:46 PM
seanth468's Avatar
iTrader Score: 5 reviews
That's where the waterpump is.
07.5 QCSB 4X4,CumminsForum leveling kit, Synergy,Anarchy,H&S O/D TCM,GDP S-3,boost tube,and ccv delete,Full Shibby egr deletes,S&B,DashHawk,B&W,Prodigy P3,AirLift,CD box brace,Borgeson,5-5100 Bilsteins,Maxx Links, 17x9 XD Hoss and Toyo AT2's.
seanth468 is offline
post #3 of 10 (permalink) Old 11-01-2011, 11:49 PM Thread Starter
That's kinda what I was leaning towards but I'm not 100% sure. It's only got 67k on it...do they typically go out this soon? My old 12v had 192k on the factory wpump b4 it started dripping.
post #4 of 10 (permalink) Old 11-01-2011, 11:51 PM
seanth468's Avatar
There has been quite a few guys on here that have had thiers go out early.
post #5 of 10 (permalink) Old 11-01-2011, 11:54 PM Thread Starter
So I'm assuming that this isn't going to be as easy as my old 97 was to swap out if it is indeed the water pump? And what do u recommend putting back on it? Oem or aftermarket
post #6 of 10 (permalink) Old 11-01-2011, 11:59 PM
seanth468's Avatar
OEM from Cummins. It's supposed to be easy. It's the same size as the 5.9 one but the 6.7 flows more.
post #7 of 10 (permalink) Old 11-02-2011, 12:03 AM Thread Starter
Man thanks for the knowledge. When I get back from cincinnati this week I'm going to look a lot closer and see what I find.
post #8 of 10 (permalink) Old 11-02-2011, 12:14 AM
bobhennick's Avatar
Mine went at 40k...haven't figured out why the pump for the 6.7L is so much more. I would recommend getting a hold of the "cummins" dealer rather than the Dodge dealer. They are generally cheaper in the parts area.
bobhennick is offline
post #9 of 10 (permalink) Old 11-02-2011, 03:50 AM
Yahooligan's Avatar
May be a little more cramped, but the process is the same. Shouldn't be much more difficult than the old 12v, I replaced the pump on my '97 in about 20 minutes and most of that was dealing with the belt and topping off the coolant.
2007.5 3500 MegaCab SLT SRW 4x4 6.7L, 68RFE w/ Mag-Hytec, XRT Pro, Diamond Eye DPF Delete, leveling kit w/ Bilstein 5100s, SnugTop Rebel shell, Insight CTS, Hell Bent Steel SBS - SOLD
Yahooligan is offline
post #10 of 10 (permalink) Old 11-02-2011, 05:30 PM
dieselhp's Avatar
Take a look at your oil filter. Do you see any dried up coolant on the top of it?
I had the O-ring go out on my hardline and ocasionally I would get a few drops of coolant on the ground. I noticed that every now and again I would see a few dried up spots on top of the oil filter.
I had to loosen a few bolts, pull the two pieces apart and repalce the o-ring.
I think I have pictures of it somewhere if you want a reference.
09, 3500, QC, long box, 4x4, 3.73, manual, high ldle, HBS 2" leveling, 35" Toyo MT, Bilstein 5100's, Mag-Hytech rear cover, South Bend 3250, 5" TBE, Smarty, EGR and cooler deleted, Carli steering stablizer, steering brace, lightforce lights, B&W gooseneck, Pacbrake air bags.
dieselhp is offline
