Best way to increase mpg - Dodge Cummins Diesel Forum
post #1 of 34 (permalink) Old 10-07-2011, 08:23 PM Thread Starter
I have a 2008 Dodge Ram 2500hd with a 6.7 cummins. I am looking for better fuel milage when towing our 10,000# 5th wheel.
Any suggestions?
What is the best chip for this application?
BUSMAN1952 is offline
post #2 of 34 (permalink) Old 10-07-2011, 08:28 PM
moose2514's Avatar
lol your towing 10 thousand pounds fuel mileage goes out the window. maybe a banks fuel economy tuner (im not sure what its called) would help you slightly but your not going to be getting good fuel mileage either way you split it. im sure you drive alot of hwy with your load and thats probably the biggest factor in getting better fuel mileage, it is what it is
07.5 s472 source 2ndgen kit stainless manifold t4 gdp 100hp nozzles ghd h&s boost tube +mani arson III fass 150 Hamilton springs, p-rods, arp 2000 carli 6" dominator EFI by kory
moose2514 is offline
post #3 of 34 (permalink) Old 10-07-2011, 11:58 PM
Yahooligan's Avatar
Suggest you keep your speed at 60mph or less. 65 or over and your mileage will drop like a rock, especially while towing.
2007.5 3500 MegaCab SLT SRW 4x4 6.7L, 68RFE w/ Mag-Hytec, XRT Pro, Diamond Eye DPF Delete, leveling kit w/ Bilstein 5100s, SnugTop Rebel shell, Insight CTS, Hell Bent Steel SBS - SOLD
Yahooligan is offline
post #4 of 34 (permalink) Old 10-08-2011, 12:13 AM
wrench04's Avatar
iTrader Score: 4 reviews
Get rid of your emissions stuff and buy a decent programmer like a smarty or H&S. Let it breath better by a decent intake and get rid of your factory exhaust, its very restrictive. Especially in the downpipe and all the filters.
I run 37" tires and can get 20-21mpg. It drops to around 15 pulling my 12000lb travel trailer.
It all depends on how you drive and programing helps big time...
2012 3500,6" Carli lift,120Hp sticks,Dragon Fire pump,ARP Studs,CPP springs,2nd gen swap,polished stainless manifold,Custom intake,tail BOV,5" SS TBE,AFE Cooler,PRXB Pacbrake,Mega Flo S-2,Grid heater delete,Fass 150,Alligator sump,Elite guages, Onboard air
wrench04 is offline
post #5 of 34 (permalink) Old 10-08-2011, 12:22 AM
Yahooligan's Avatar
Yes, you can always do the deletes and get a tuner, but you need to consider the cost vs. reward. Doing mods PURELY for MPG gains takes quite a while before the cost of the mods is recovered in fuel savings.
My truck gets 11.5-12mpg towing an 8000lb travel trailer. At $4.02/gal (current price), that's $0.342/mi. If the tuner+deletes brought that up to 14mpg then that would be $0.287/mi, a savings of $0.055/mi. If the tuner and delete pipe (Cheapest option) cost $800, then saving $0.055/mi it will take 14,500 miles to reach the break-even point.
If my freeway mileage were to go from 18mpg to 20mpg, a savings of $0.022/mi, it would take 36,000 miles before I broke even on the mod.
So yes, doing the deletes ONLY for increased fuel economy will eventually pay for itself if you drive enough.
I find just slowing down is the cheapest way to save money on fuel. I'll be doing the deletes, but not only for fuel economy gains.
The Following User Says Thank You to Yahooligan For This Useful Post:
becdino (11-03-2011)
post #6 of 34 (permalink) Old 10-08-2011, 12:28 AM
wrench04's Avatar
Depends on how long you plan on owning the truck. If you plan to keep it for any length of time the mods definately pay out in the end not in just fuel saving but longevity of the engine and components as well.
A programer will adjust the timing curve and make the engine run much more efficiently, the deletes will stop the engine from recirculating exhaust gas back into your intake and carboning up your whole system. It will save in turbos as well as their is less carbon running through the engine.
If you are going to get rid of it in a few years, just buy a programer that will shut off the emissions and make yourself up some block off plates, won't cost you much at all.
wrench04 is offline
post #7 of 34 (permalink) Old 10-08-2011, 12:33 AM
DQL
My 2005 Dodge 5.9 averaged almost 13mpg during our 7500 mile summer towing our 13500 lb fifth wheel. Our 2008 Dodge 6.7 gets almost 3mpg less than the 2005 5.9 and I think the main difference is the BlueTec emissions stuff. Just a thought.
DQL is offline
post #8 of 34 (permalink) Old 10-08-2011, 12:35 AM
wrench04's Avatar
That is correct and also the reason that emmision stuff "falls off" of so many trucks.
wrench04 is offline
post #9 of 34 (permalink) Old 10-08-2011, 07:50 AM
cowcatcher's Avatar
It only cost me $445.xx for a mini maxx and delete kit. You can cash the old exhaust in. I gained 5mpg loaded or empty. It wont take long to pay off. But, I still dont see 20+. I probably drive too fast.
2010 cclb dually,4wd, G56,Valair DD, H&S MM,deleted,5"tbe
2004.5 crewcab 2500 6spd 2wd (stock for now)
cowcatcher is offline
post #10 of 34 (permalink) Old 10-08-2011, 05:28 PM
cabanaman's Avatar
You can start by unplugging your egr and ignore the cel.
(Sold) 2007.5 2500 SLT sport 2wd,6 spd auto, EGR delete, DPF delete pipe, Sims, Intake baffle pulled,CCV gutted Hypertech econ 50hp tune
cabanaman is offline
post #11 of 34 (permalink) Old 10-14-2011, 12:40 PM
Do the deletes you will not regret it. I did the deletes with the Smarty JR and gained an honest 5.5 mpg.
tmprks is offline
post #12 of 34 (permalink) Old 10-14-2011, 09:14 PM
Yahooligan's Avatar
Is that US or Imperial MPG? I can see 2-3mpg US, the only way I can believe 5.5 is if you're in Canada.
