what type of coolant does the 6.7 take? - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 09-09-2011, 01:41 PM Thread Starter
moose2514's Avatar
goin to the parts store tonight to get coolant as im doing a flush tomorrow. what is the correct fluid and how much does it hold?
moose2514 is offline
post #2 of 19 (permalink) Old 09-09-2011, 02:10 PM
I'm pretty sure it's the fleet guard which is "pink". My local oreilly's doesnt carry it.
1qwkgoat is offline
post #3 of 19 (permalink) Old 09-09-2011, 03:20 PM Thread Starter
moose2514's Avatar
someone said it was zerex G 05 coolant
post #4 of 19 (permalink) Old 09-09-2011, 03:36 PM
08 Cummins
KhakiCummins's Avatar
According to the owners manual, it needs to be a HOAT (Hybrid Organic Acid Technology) antifreeze. When I was looking, the only one that I could find other than Mopar was the Zerex G05.
Valvoline.com > Products > Zerex > Antifreeze Zerex > Zerex G-05 Antifreeze / Coolant
Duane
2008 Ram 3500 QuadCab
Hamilton 103# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
2014 Jetta TDI 6 SPD Manual
KhakiCummins is offline
post #5 of 19 (permalink) Old 09-09-2011, 07:07 PM
mr. ed's Avatar
Zerex G 05 coolant is correct. I happened to pick some up yesterday after I had the clerk verify on his computer that it's the right stuff. The bottle also says on the back that it is for Dodge Cummins up to 2006 and later.
I was a little concerned about the color, though. It isn't pink but sort of yellowish. I just added enough to bring the level up in the recovery tank. Hopefully it will mix well with the pink stuff.
2007.5 RAM 3500/6.7/G56/4WD/SB/SRW/mineral gray/Big Horn edition/bone stock
2007 Hitchhiker 29.5 LKTG fifth wheel
mr. ed is offline
The Following User Says Thank You to mr. ed For This Useful Post:
hurst238 (09-29-2012)
post #6 of 19 (permalink) Old 09-10-2011, 04:21 PM
LittleOleHotShotter's Avatar
Wish I new the difference. Half my trucks life was green the other half gold. Never noticed a difference. From what I saw. Now that I got my modded radiator from puredieselpower.com I went back to gold. I try not to be outlaw to much.
TRUCK IT TRANSPORT
LittleOleHotShotter is offline
post #7 of 19 (permalink) Old 09-10-2011, 04:59 PM
COFFMAN CUSTOMS
AH64ID's Avatar
Zerex G05 is the factory fill, but the Mopar bottled stuff is orange, the OEM is pink, and the G05 off the shelf is yellow.. but it's all Zerex G05.
There are many coolants that HOAT does not mix with (regardless of what the bottle says) and can gum up and give you lots of issues.
This is a 5.9, but no difference. Coolant flush on a 3rd Gen.
AH64ID is offline
post #8 of 19 (permalink) Old 09-11-2011, 12:24 AM
Napa has the right stuff. Napa part number for the 50/50 pre-diluted HOAT Zerex G05 is "ZXG05RU-1" and lists for $13.11/gallon
2006 3500 MegaPig | Carli Trussed 6" Long Travel Dominator
ant.foste is offline
post #9 of 19 (permalink) Old 09-11-2011, 12:40 AM
COFFMAN CUSTOMS
AH64ID's Avatar
You don't want to use pre diluted in these blocks or you will end up with a very weak mixture... Look at the post I linked it explains why.
AH64ID is offline
post #10 of 19 (permalink) Old 09-11-2011, 01:05 AM
For a flush situation you are very correct.
For a topping off situation the premixed works fine.
The Following User Says Thank You to ant.foste For This Useful Post:
blackriflerecon (03-08-2014)
post #11 of 19 (permalink) Old 09-11-2011, 10:40 AM
COFFMAN CUSTOMS
AH64ID's Avatar
Correct, and since this is a flushing thread the pre-mix isn't applicable.
Just don't want guys to end up with the wrong stuff.
AH64ID is offline
post #12 of 19 (permalink) Old 09-11-2011, 02:31 PM
disposablehero's Avatar
iTrader Score: 4 reviews
Went hunting for coolant today, Napa is closed and the other guys don't carry it. Had to use water and I guess I will have to drain a bunch and re fill. I may go ahead and flush her out.
FOR SALE $20K 07 6.7 QCSB, EFI LIVE BY DAVE MATTHEWS, dpf and egr junk fell off, gh delete, arp studs, modded cp3, tuned tcm on 35"s. 487/ 1100 with a slipping stock tranny. 13.6@98.6
disposablehero is offline
