OBD II Scanner tool - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 08-25-2011, 12:47 AM Thread Starter
OBD II Scanner tool
I've unplugged the dreaded DPF killing EGR valve, but now the CEL light is on all the time. I've heard that certain code readers can also turn the CEL off, but that the CEL will soon come back on again...
Short of plugging-back in again the EGR harness, is there a scanner that will keep the CEL light off with the EGR unplugged??
If so, I have no idea which scanner to buy...
Thanks,
Bunkysdad
bunkysdad is offline
post #2 of 8 (permalink) Old 08-25-2011, 01:04 AM
thepitts5's Avatar
Any scanner should, with ignition in the run position engine off, clear codes and then start, but do you really want to do that every time you start the truck? Not to mention it might mask a real fault from triggering the CEL.
'08 QCSB known as "The Money Pit"
thepitts5 is offline
post #3 of 8 (permalink) Old 08-25-2011, 10:11 AM Thread Starter
Maybe I should have shortened my question...I'll try again...
"Short of plugging-back in again the EGR harness, is there a scanner that will keep the CEL light off with the EGR unplugged??
If so, I have no idea which scanner to buy"...
post #4 of 8 (permalink) Old 08-25-2011, 10:15 AM
thepitts5's Avatar
Let me break it down for you, NO.
My previous post was telling you how to do it with the egr unplugged.
post #5 of 8 (permalink) Old 08-25-2011, 11:15 AM Thread Starter
Ok, sounds like I'll have to live with having the CEL light constantly on...So I'll likely have to buy a chepo scanner just to occasionally check for other CEL alerts...
Thanks,
bunkysdad
post #6 of 8 (permalink) Old 08-25-2011, 05:50 PM
sikesix's Avatar
If you are just wanting to read the codes, you can do that with just the ignition key.
Turn the ignition on (without starting the engine) and off three times quickly (leaving it on the last time) and write down the numbers that scroll across where your odometer is. You can then use this forum to find out what the codes stand for.
08 6.7 auto 6spd QC 8' box ST 4X4 3.73 tow pkg / Scout II with EGT probe, Leer topper, Mag Hytec Rear Diff., Hankook Dynapro ATS 285-70R17 / wheels American Outlaw "Buckshot", front bumper "Ranch Hand"
sikesix is offline
post #7 of 8 (permalink) Old 08-25-2011, 08:01 PM Thread Starter
Thanks for the good tip...Sounds like for my purposes the way to go... Seems theres no real sense for a scanner since it won't permanately shut off the EGR CEL alert...
post #8 of 8 (permalink) Old 08-25-2011, 10:55 PM
cabanaman's Avatar
Thanks,
bunkysdad
That's correct my cel and I have been good friends for 40,000 miles.You can do code checks using the key method and your odometer,look it up.
(Sold) 2007.5 2500 SLT sport 2wd,6 spd auto, EGR delete, DPF delete pipe, Sims, Intake baffle pulled,CCV gutted Hypertech econ 50hp tune
cabanaman is offline
