valero gas stations selling bio diesel in texas. WTF? - Page 2 - Dodge Cummins Diesel Forum
post #13 of 32 (permalink) Old 08-14-2011, 10:28 AM
mikmaze's Avatar
I go out of my way to find a station with bio, runs better in the truck, and keeps it clean. if you never ran a batch before keep a spare fuel filter in the truck and tools to change it just in case. A good practice to do anyway. As for the ethanol and small engines, run super, much beter for all small engines, 2 strokes even more so.
04.5 Qcab shorty Evil twin cp3's 210 over stock nozzles. HTT 64 71 13 ss over S 480, arp's Hamilton 181/ 210 cam and springs, GOEREND 48RE, UDC FTW!
2006 Liberty CRD w/ eco tune from GDE soon to b straight piped JD 1070 dzl
mikmaze is offline
post #14 of 32 (permalink) Old 08-14-2011, 10:49 AM
ZOP
Decoder Ring Specialist
ZOP's Avatar
Originally Posted by Danderson View Post
I'm not aware of B5 in Mexico. They only have LSD on the mainland. That's why the 4th gens come from the factory w/o DPF's,only cats and EGR's.
Sulphur is what destroy's the NOx catalysts ability to work especially IIRC ... http://www.nrel.gov/docs/fy02osti/31600.pdf -- I can't remember if there was any problems with the DOC and DPF though I'd have to reread the report. Yup, a bit "old" but the conclusions are still valid, and are part of what our current ULSD formulas and emissions control systems and laws are based on.
2011.5 6.7L HO 3500 4x4 ST Crew LB 3.73 SRW Rear 68RFE H&S MM w/ Custom Tuning, B&W+Companion
60 Gal RDS Tank/Tool PacBrake Bags
2012 Fuzion FZ305 35' Toy Hauler (no, the Ford does not pull this...)
ZOP is offline
post #15 of 32 (permalink) Old 08-14-2011, 10:50 AM
ZOP
ZOP's Avatar
Not all super is ethanol free though. Atleast not here in montana. There are a handful of stations that do specifically sell ethanol free premium/super gasolines though. My 2006 Harley night-rod can *definitely* tell the difference.
ZOP is offline
post #16 of 32 (permalink) Old 08-14-2011, 10:54 AM
ZOP
ZOP's Avatar
Page 84 in the 2011 Diesel Supplement
A maximum blend of 5% biodiesel meeting ASTM
specification D-6751 may be used with your Cummins
 diesel engine.
It also further states about No. 1 diesel:
No. 1 Ultra Low Sulfur diesel fuel should only be used
where extended arctic conditions (-10F or -23C) exist.
I've seen articles about the "20% approved" in the 2001/2002 and maybe 2003... 5.9 12v/24v/etc engines, IDK about prior to 2011 6.7L's but atleast for 2011 they're saying B5 and no more.
ZOP is offline
post #17 of 32 (permalink) Old 08-14-2011, 10:57 AM
ZOP
ZOP's Avatar
For 2004 RAM 3500 Diesels no biodiesel is actually apparently approved:
NOTE: As sufficient testing has not been completed,
organically blended diesel fuels (e.g. biodiesel, ethanol,
and methanol blends) are not recommended or approved
for use with your Cummins Diesel equipped Dodge Ram
Truck.
ZOP is offline
post #18 of 32 (permalink) Old 08-14-2011, 08:51 PM
Originally Posted by 2007 cummins 6.7 liter View Post
Is there a mandate to sell B5 now just like they sell ethanol or is it just valero? Cause all the valeros had stickers and the chevron station I went to didn't.
I am a fuel dispatcher, and I can tell you that over in Memphis, TN at the Valero terminal that is all you can get. Valero Terminal does not sell any Diesel that does not have at least 5% bio in it. Honestly 5% is not that much, and I doubt you would have any problems running it in your truck.
sgood is offline
post #19 of 32 (permalink) Old 08-15-2011, 12:00 PM
Diesel Filled Veins!
Sandman76's Avatar
Originally Posted by ZOP View Post
Anything with ethanol is a pain in gas engines, no water seperators. Plus water mixed with ethanol settles to the bottom of the tank. Ethanol also very actively absorbs water from the air. I heard a statistic that something like 50% or more of the ethanol based gasoline is out of spec by the time it is pumped into a cars tank.
Does the water settle to the bottom of your 40oz ethanol tank in your cupboard (rye, vodka, rum etc)? Water settles to the bottom of all fuel storage tanks gas or diesel unless it combines with the Ethanol as you said. Ethanol and Methanol are missible in water so yes, they will absorb water and degrade your fuel.
#3 ATS Stage IV - So Far So Good
EPA "Race Tuned" with EFI Live By DaveMatthews, Edge CTS; Fred Goeske dually spacers
2008 - - M - E - G - A - DUALLY - -
Sandman76 is offline
post #20 of 32 (permalink) Old 08-15-2011, 12:06 PM
pepsi71ocean's Avatar
Originally Posted by DieselRiot View Post
Couple of sunocos in nj have it also.
Sent from my DROID2 using Tapatalk
do you have a list of sunoco's that have b5? ide like to try some of that and test it compared to running 2 stroke oil.
99 3500 Built DTT Auto, 600 lower TC, 3.55, 4x4, BHAF, 6" lift, ARP's, Danin Optix, Gauges, DAP 100hp sticks, FASS 95, 2LO kit, HIGH Idle, Silencer ring delete, 4" exhaust, SMARTY, 03 VW PASSAT 1.8T Big Thanks to (FTE Diesel),(DAP),(DTT)
They ROCK!
pepsi71ocean is offline
post #21 of 32 (permalink) Old 08-15-2011, 12:14 PM
ZOP
ZOP's Avatar
Different densities, once the ethanol in gasoline absorbs water, it becomes heavier, and sinks out of the gasoline along with the water, drastically lowering the octane level of the gasoline. Large storage tanks are constantly having air mixed into them by virtue of filling and emptying. It adds up. A container of only ethanol is not going to behave the same as a container of gasoline that is mixed with ethanol. Normally they'll stay mixed together, but add water, and the water+ethanol mixture tends to settle out of the gasoline. It probably takes some amount of additive packages along with it too.
ZOP is offline
The Following User Says Thank You to ZOP For This Useful Post:
Sandman76 (08-15-2011)
post #22 of 32 (permalink) Old 08-15-2011, 12:58 PM
Sandman76's Avatar
Makes sense for sure now that you explain it that way.
post #23 of 32 (permalink) Old 08-16-2011, 10:22 AM
BULLETS's Avatar
B5 Bio is MAX ON 2007.5'S according to the manual.....Haven't seen it South Texas-Yet..
2007.5/3500/6.7/68RFE/QC/SB/SRW/TRXOFFROAD/4.1/SLT/S&B/FRTRPLBPR/TOOLBOX/RCHTRK/ 33"MTR's KEVLAR, EFI, PUSHER, GDP CONV., D. PIPE, 2" leveling kit.
BULLETS is offline
post #24 of 32 (permalink) Old 08-16-2011, 12:54 PM
Given the questionable character of some of the Valero franchises in my neck of the woods, I wouldn't be surprised if they were just dumping the old grease from the burrito fryers into the diesel tank and sticking a B5 sticker on the pumps.
CtAlucard is offline
