68RFE Transmission Temps? - Page 2 - Dodge Cummins Diesel Forum
post #13 of 32 (permalink) Old 07-29-2009, 11:05 AM
Suspension Specialist
ban89's Avatar
in that type of heat you are probably going to need a AUX trans cooler with this truck as well. everyday driving unloaded with the TC locked I stay between 130 and 160 but. Hot days 90*+ in stop and go traffic unloaded I can get to 190 with the TC unlocked and have gotten as high as 230 offroading slow. If you can keep the TC locked the trans cools fast but in those situations where you're towing heavy and in stop n go or going slow up a steep grade your trans temps are going to get high quick.
I also have a PML deep trans pan and am taking the temp from the hot line.
You can try down shifting into a lower gear but its hard to keep the TC locked even with Tow/haul on if you are dropping speeds below 25mph consistantly. If you do get too hot pull over and thorw the trans in N and it will cool off a bit. A remote AUX trans cooler with fan is your best bet. I'll be getting one before next desert season.
ban89 is offline
post #14 of 32 (permalink) Old 07-29-2009, 01:49 PM
moeszyslak's Avatar
250* @ hotline- 90* out & towing 11k, stop and go for an hour.
'07 6.7L 4x4 Laramie megacab dually-lloonng bed Banks scoop, FOR SALE!! Ebay
moeszyslak is offline
post #15 of 32 (permalink) Old 07-29-2009, 03:59 PM
I recently returned from trip out to NW Montana and saw 145- 165 at outside temps up to 80 or so running 65 mph. I was towing 11m lbs. and use an Edge Insight for gauges. I saw 185 in stop and go traffic . In the Badlands it was near 95 and I briefly saw 207 on the winding road near the end of the loop.
Glad I put the PML pan on.
2007.5 , 6.7 , SLT Q.C. 4x4 , Auto, Air Raid intake , Hypertech Max Energy on Level 2, EGR unplugged , Edge Insight , PML Trans Pan , Firestone Airbags.
Rrloren is offline
post #16 of 32 (permalink) Old 07-29-2009, 04:19 PM
You're wrong! Get over it
dad2bike's Avatar
I've been running in the 165-175 range these days. Our temps have been in the 1-teens.
I'm installing a Mag-Hytec pan This weekend. It will be interesting to see any temp drops with the extra capacity.
Tom
2008 QC-LB,2500,4X4,White/Kaki,Big-Horn,3.73 Auto, MyGig Nav unit, K&N no baffle,DPF quit working, GHD, Shibby stage 1 intake & boost tube, Smarty, PMT for gauges, Mag-Hytec Pan & Diff covers.
SNAFU
dad2bike is offline
post #17 of 32 (permalink) Old 07-29-2009, 04:41 PM
It will be nice to see what the new pan does for you. I've read some other posts some where a while back that even with the larger pan it got just as hot but just took a little longer to get there. I dont know how true this is and is why I havent bought one yet. For now I'm just draining and filling every 20k.
08 Megacab 2500, Laramie, 6.7, 68RFE, 4x4, 3.73, 5" SS TBE, Smarty 14ME, No Intake Baffle, Modified Airbox W/ K&N, EGR Delete, EGR Cooler Delete, Edge Insight, Airdog 2, Shimmed FPRV, MHP/B&G Modified TCM, B.O.D. EWG, ARP 625's, GDP GHD.
INFERNO MEGA 08 is offline
post #18 of 32 (permalink) Old 07-29-2009, 05:10 PM
I have the extra large PML pan. 4 quarts extra. No noticeable drop in tranny temps.
2008 Dodge 3500 SRW QC LB 4x4, Auto, 3.73, 6.7L. Thuren springs. Thuren TB, HID's. All deletes. Smarty. 4040XL. Banks SuperScoop. RockCrusher diff guards. Defiant steering support & stone shield. Goerend TC. WCC intake & boost tube. No grid heater. King 2.5" shocks, Carli CA, Yokohama 37", Flex-a-lite fan, Carli Sway bar, Sulastic shackles, MHP trans tune, 3 - Hella 4000's w/55W HID's on Defiant bar.
milo12 is offline
The Following User Says Thank You to milo12 For This Useful Post:
dad2bike (07-29-2009)
post #19 of 32 (permalink) Old 07-29-2009, 11:13 PM
Sounds to me like adding an additional trans cooler w/ fan is the answer to our temp. issues. I wonder if adding a fan to the existing cooler would be as good?
post #20 of 32 (permalink) Old 08-01-2009, 12:30 PM
200+ the other day while shuffling between redlights in mid 80s weather. It went down once I got away from the traffic.
slagburn is offline
post #21 of 32 (permalink) Old 08-01-2009, 03:55 PM
XLR8R's Avatar
None of the tranny temps posted are in a synthetic's danger zone, but if you want to increase cooling - as opposed to merely delaying overheating - an auxiliary tranny cooler is the best bet... the OEM unit mounted to the CAC "ain't that big".
3 Nails Garage- home of LazarSmith
Sleeps a flock of Rams & a Goat
GUN-HAPPY Crew Chief
XLR8R is offline
post #22 of 32 (permalink) Old 08-02-2009, 02:31 AM
There is more to a tranny then the fluid, clutch linings and seals will not enjoy sustained 220*F+ operation
Lead Head is offline
post #23 of 32 (permalink) Old 09-03-2009, 11:41 AM
Retired Engineer
Courierdog's Avatar
There was a post where someone added an aftermarket transmission cooler in place of the OEM version but I cannot locate it.
2007 6.7 L, 2500 QC, Laramie, SB, 3.42, Mag-Hytec, 68RFE, Harvard 750 Bypass Oil Filter, Patriot Blue, 4X2, Michelin LTX Summer, Michelin X Winter, Raider Canopy, HERD Bumper, Espar Cab Heater, Sirius, Smarty 25ME, SS636, WCC Intake Manifold & 3.5 inch Boost Tube, Donaldson 100580, PMT Gauge Set, Smarty, Optima Red Top Batteries, Have Truck, Will Travel
Courierdog is offline
post #24 of 32 (permalink) Old 09-03-2009, 05:53 PM
Drbrodent's Avatar
Originally Posted by mileshuff View Post
I'd like to hear temps from someone who tows in 100+ degree with long steep 6%+ mountain grades. I live in AZ and thats a common summer issue.
Also wonder how water temp holds in extreme heat towing conditions.
My Hemi Durango starts to get hot and the auxillary cooler kicks in (its loud) and the water temp drops instantly. No issues towing in our extreme heat.
I pull my 9k TH around Utah all summer, one of my favorite spots is up a very steep 8% 20 mile twisty grade and as long as I can keep the speed up I dont have any problems at all...its the slow steep dirt roads that will give you trouble with your trans temps (4low cures it) but I have never had the truck coolant get above 210.
2014 3500 Mega Laramie, 4.56 gears, BDS lift, Fox shocks, 37" Toyo's on 22" BMF Novakanes
Drbrodent is offline
