What years are Pre DEF emissions - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 01-28-2011, 01:20 PM Thread Starter
jrosp23's Avatar
Anyone know what years are Pre- DEF emissions for Dodge, Ford and Chevy.
I am curious when each MFG started using the DEF fluid.
thanks,
Jeff
2006 Quad CAB 2500 CTD, ATS ARC Flow Intake, K&N Filter, 4" MBRP Turbo Back Stainless, FASS 150 lift pump, Bully Dog Triple Dog Programmer, Hell Bent Steel 2.5" leveling kit, 2" Rear lift. 305/65 R17 Pro Comp Xtreme AT's Stock Wheels
jrosp23 is offline
post #2 of 11 (permalink) Old 01-28-2011, 01:50 PM
Unreconstructed
Alabama Mud Machine's Avatar
My bad......Not sure what DEF fluid is. Sorry, thought you were asking about what all years had DPF's on them, and just forgot to use spellcheck.
2011 Chevrolet 1500 LT Z71 Crew - 5.3 / auto, Ranchhand guards, 275//70/18 Toyo MT's
2007.5 Ram 2500 QC/SB 4x4 - 6.7 / 68RFE - EFI Live tuned, and a bunch of other stuff
1996 Ford F-250 4x4 - 7.3 PSD / ZF-5 - Awaiting built 12V swap
Special thanks to:
, Shibby Engineering, Black Ops Diesel, Motorsport Diesel, EFI Live, & Hardway Performance
Alabama Mud Machine is online now
post #3 of 11 (permalink) Old 01-28-2011, 01:53 PM
Mr. Vehicle Destroyer
Shibbyutman's Avatar
iTrader Score: 7 reviews
2011 GM and Ford both phased in DEF. Dodge/Cummins has on their Chassis and Cab trucks for 2011 (2010? maybe even) as well, but their regular trucks 2500 and 3500 will not use DEF for several more years.
Back in the common snail game. 03 SO 2wd 480,000 miles and counting.
Parts for sale: Van Aken SmartBox, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. RACEME 07-09 Delete Tuners
Shibbyutman is offline
post #4 of 11 (permalink) Old 01-28-2011, 01:58 PM
COFFMAN CUSTOMS
AH64ID's Avatar
Originally Posted by Alabama Mud Machine View Post
Dodge: 2007.5+ 6.7 Cummins diesel engines
Ford: 2007+ 6.4 PowerStroke Diesel and 6.7 Scorpion diesel engines
Chevy: All 2007.5+ LMM and LML Duramax diesel engines
Not quite.
Dodge doesn't yet use it on their pickups, but its now on the 2011 C&C.
Ford uses it on 2011+ trucks.
GM uses it on 2011+ trucks.
AH64ID is online now
post #5 of 11 (permalink) Old 01-28-2011, 02:27 PM
Unreconstructed
Originally Posted by AH64ID View Post
Not quite.
Read edited post......Thought he was asking about DPF's, my bad.
Special thanks to:
post #6 of 11 (permalink) Old 01-28-2011, 02:41 PM Thread Starter
jrosp23's Avatar
yeah, i am just interested what year trucks do not need the Diesel Exhaust Fluid added every 5k miles. My dad is old school, he bought a brand new duramax and is fed up with paying for 5 gallons of fluid every couple months. We are in western new york, he had it freeze up on him and check engine light is on because of the DEF was frozen, he is just fed up with it. I told him to buy a cummins.... you just cant convert the chevy guys.....
jrosp23 is offline
post #7 of 11 (permalink) Old 01-28-2011, 02:51 PM
Tell him to go to the dealership, there was a TSB that requires a reflash to fix the issue of DEF freezing and throwing a CEL.
Also, he should be glad he has DEF. Injecting DEF means less EGR. Would you rather pay 15 bucks for some to inject into the exhaust every few months, or pay zero dollars and have the EGR valve recirculate a ton of soot back into the intake? Sure, the Duramax still has EGR but it's not nearly as much as the Cummins, because the EGR and the DEF are both doing the same thing.
tokes is offline
post #8 of 11 (permalink) Old 01-28-2011, 04:17 PM
'11 for the Ford and Chevy, also the '11 dodge HD C&C. Dodge is slated to go away from the troublesome DPF and start using DEF in all the 6.7's for the 2012 model year. According to Chrysler's Service Masters DEF should be refilled every 10k miles and will not trigger CEL if frozen. Truck will run normally until heater can unfreeze fluid.
Itspoofdun is offline
post #9 of 11 (permalink) Old 01-28-2011, 04:21 PM
Ram3500Dually's Avatar
Highly doubtful you will be seeing DEF on the 2500/3500 in the 2012 model year. Nothing is in the plans right now. Cummins is working on something else to meet the next set of guidelines and it doesn't involve DEF.
As for others using DEF, anything manufactured after December 31st 2009 is using DEF other than the 2500/3500 Dodge.
2013 Ram 3500 Dually CTD 6.7/Aisin/4:10 LSD
Previous Rams:
90 CC Dually, 94 RC LB, 95 CC SB, 98 QC Dually, 00 QC Dually, 01 QC Off Road, 03 QC Dually, 05 QC Dually, 08 QC Dually, 10 CC Dually
Ram3500Dually is offline
The Following User Says Thank You to Ram3500Dually For This Useful Post:
DodgeMech (01-28-2011)
post #10 of 11 (permalink) Old 01-28-2011, 06:11 PM
Just to clarify, it's only the engines manufactured after 12/31/09 that are DEF from Ford and GM. There are quite a few 2010 Silverado's and Sierras with a build date into 2010 with no DEF because they were built using older LMM engines produced in 2009.
tokes is offline
post #11 of 11 (permalink) Old 01-28-2011, 06:57 PM
I'll have to dispute that. The 2010 Emissions standards were set for Jan 1st 2010. NOTHING was allowed to be produced after that date that wasn't compliant.
Why the need for a new round of updates to the Duramax just three years after the current engines arrived? Come Jan. 1, 2010, all new diesel-powered vehicles will have to meet tougher federal diesel emission standards that will reduce allowable nitrogen oxide levels by 90 percent from today, 96 percent from 1994 levels.
First Look: 2011 Duramax Diesel V-8 Engine - PickupTrucks.com News
Previous Rams:
