2008 6.7 head gasket - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 08-31-2010, 09:58 PM Thread Starter
brndn3050's Avatar
does anyone know where i can cross reference the cummins part numbers with the dodge house part numbers or should they be the same?
the dodge head gasket part number is 68014-991aa
the cummins head gasket part number is 4932210 but they said they had at least 2 other head gaskets for the 6.7
brndn3050 is offline
post #2 of 3 (permalink) Old 08-31-2010, 10:05 PM
There should be only one part # from cummins now there was a change a few months ago
2008 6.7, 5" TBE 7" tip, Smarty, Air Dog, Tranny pan, 4 Guage pod on winshield, Custom light bar,2" level kit, 35" Toyos
spot is offline
The Following User Says Thank You to spot For This Useful Post:
brndn3050 (08-31-2010)
post #3 of 3 (permalink) Old 09-01-2010, 12:01 AM Thread Starter
brndn3050's Avatar
i tried to order a single head gasket, and i installed a 6.7 in my 03 so i needed the rest of the gaskets for a 5.9 so i kinda wanted to see if they would piece a gasket set for me. but the parts guy at the cummins house in odessa told me there were 2 different head gaskets in the 6.7 gasket set and asked which one i needed. i had previously ordered one from them a month prior and that gasket wasnt even in the gasket set. so there were 3 different head gaskets for the 6.7 at the cummins house. i then called the dodge house and got their part number for the head gasket they sell and it didnt match the one i put in. i have a horrible leak of water into my oil pan, and i have researched almost every problem minus a cracked head or block. but today i put an old head gasket to the 5.9 head and im not sure of the exact difference in the head whereas water jackets and oil returns are concerned but there were a few that didnt match. the water is freely flowing into my oil pan as fast as i can put it into the radiator so wherever the hole is its pretty big. i wanted to check the gasket that came out (the first i bought from cummins that wasnt in the set, also the same one that is in it now) against the gasket from dodge.
