G56 Gear Rollover - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 05-30-2010, 09:00 AM Thread Starter
trophytime's Avatar
G56 Gear Rollover
Recently installed Southbend Dual Disc.
Now the gear rollover from the tranny is horrible..
I drained and filled the tranny with 7qts RP Syncromax.
It is definitely quieter when the oil is cold.
I'm wondering if draining & adding a quart of Hy-Per Oil Supplement would hurt anything? I'm wanting to increase the viscosity a smidge.
2008 Dodge Ram 2500, Quad Cab, Long Bed, Laramie w/ Sunroof, 6.7 Cummins, 6 Spd Manual, Black Tool Box & Bed Cover, SB 3250 DD Clutch, Edge Insight Gage, 5" SS TBE w/ Magnaflow Resonator, XRT and now I'm code free!
trophytime is offline
post #2 of 17 (permalink) Old 05-30-2010, 09:42 AM
From what I read I think it's the nature of DD clutches to produce more gear noise. There's a good article part way down here:http://www.techcapri.com/PDF/Repair/...ice_S08-00.pdf
It doesn't sound like there's much that can be done.
07 6.7 2500 Laramie LB 4x4, 68RFE, 19.5" Ricksons, 265/70/19.5 Toyo M608Z
Pics at
jomobco is offline
post #3 of 17 (permalink) Old 05-30-2010, 10:20 AM
700kenny's Avatar
iTrader Score: 5 reviews
A fluidamper should help some to if the oil does not get it quiet . I have one plus added lucas tranmmison addttive ,noise is almost completly gone.
07 dodge 2500 6 speed ,smarty box,airdog ,BDintake , south bend 3600 daul disc clutch,isspro's, fluidamper HTT 64mm
700kenny is offline
post #4 of 17 (permalink) Old 05-30-2010, 10:47 AM Thread Starter
trophytime's Avatar
Do you have a 5.9 or 6.7? From what I understand, fluid damper can help the 5.9 but is of no value to 6.7 as it already has one. I'm a 6.7
But I'm willing to try about anything - even returning to stock at this point.
post #5 of 17 (permalink) Old 05-30-2010, 01:59 PM
Any thoughts on a durable aftermarket DMF? I bet SBC or ATS could come up with something quiet for those of us not running huge HP and routinely towing an office building over the Rockies. Anyone have pics of the stock DMF? Was it almost falling apart when it came out? I'm certainly no expert but a more robust DMF with a single disc clutch that could handle a bit more HP than stock seems like it'd be a good seller.
08 QC 6.7 Silver 4X4, G56, Amsoil Bypass, DiPricol Boost & Pyro, MagHytec Rear Diff Cover, Dynatrac Freespins w/Dynalocs, SMARTY, Fleetguard separator/CAT1R-0750, Auto On EB switch. Thank you LEFT COAST DIESEL
Tractortug is offline
post #6 of 17 (permalink) Old 05-30-2010, 02:31 PM
Danderson's Avatar
Stronger DMF?
I spoke to a LUK rep about just that subject. He was a DMF- equipped Dodge owner and acknowledged a market exists for a DMF with maybe 50-100 hp over stock. He said he'd bring it up with the engineers and marketing. Maybe a few more e-mails would help. The SBC OFE is supposed to be nearly stock like in noise and manners. I keep my Smarty@ sw#3 and luckily I inherited the lower final drive. 285-75-17's a constant 2000# load and no slippage yet.
'07 2500 SLT,5.9,regcab.,G-56,4wd,Northstar TC800 popup 24/7. SBC OKHD. Toyo AT2's. Dynatrac freespins and bj's. Synergy HD steering. Suspension mutt courtesy of Kore, Carli and Thuren.
Danderson is offline
post #7 of 17 (permalink) Old 05-31-2010, 06:51 PM
700kenny's Avatar
Originally Posted by trophytime View Post
do you have a 5.9 or 6.7? From what i understand, fluid damper can help the 5.9 but is of no value to 6.7 as it already has one. I'm a 6.7
but i'm willing to try about anything - even returning to stock at this point.
5.9.........................
700kenny is offline
post #8 of 17 (permalink) Old 05-31-2010, 10:56 PM Thread Starter
trophytime's Avatar
I sure agree. Who is LUK?
post #9 of 17 (permalink) Old 05-31-2010, 11:01 PM
Danderson's Avatar
LUK manufacturers our stock dmf.
post #10 of 17 (permalink) Old 12-27-2013, 11:22 AM
Kody_Shortydually's Avatar
I just got with Dan at valair clutches and they offer the new quiet series. ill be getting mine installed tomorow so i can leave feedback after break in.
2012 CCSB American Force 22's, Leveled
Fully Deleted, EFI, MBRP, More Coming
Kody_Shortydually is offline
post #11 of 17 (permalink) Old 12-27-2013, 05:52 PM
Valair Inc. Clutch
Valair1's Avatar
The quiet one is in regards to floater plate rattle, the floater when clutch pushed in is silent, gear rollover is a entirely different issue, while we as well as others have made progress, it cannot be ruled out when changing over from a dual mass to single mass flywheel. I also assume we are installing yours in the morning?
97 12V The Farm Truck Too much to list.
99 QCSB 4x4 Sport. Compounds,Big fuel, Built Auto etc....
13 CCSB 4x4 Laramie, EFI Live
15 CCDRW 4x4 Tradesmen Still Stock.
[/COLOR]
Valair1 is offline
The Following 2 Users Say Thank You to Valair1 For This Useful Post:
Danderson (12-27-2013), N1NJ4ON3R (12-28-2013)
post #12 of 17 (permalink) Old 12-28-2013, 01:17 PM
N1NJ4ON3R's Avatar
gear rollover is the nature of the beast when changing from dmf to a smf. if you don't lug it you wont hear it. me I kinda like the sound.
-2008 6.7l QCLB 4x4,g56,J-67(23ME),valair DD,64.5/72/14,2nd gen mani,arp 425's,boost and pyro... -1993 W250 CCLB...
-1996 brewed s14 w/ 386 rwhp & 341 rwtq @19psi twinscroll baby!!!(gt3076r)
N1NJ4ON3R is offline
