no glow plugs - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 08-04-2007, 04:39 AM Thread Starter
eobigbull's Avatar
no glow plugs
I was test driving my new megacab last night and i asked the salesman where the display for the glow plugs was at and he said its no longer there. Am i crazy or just ignorant. NO GLOW PLUGS?
eobigbull is offline
post #2 of 12 (permalink) Old 08-04-2007, 05:37 AM
95dodgectd's Avatar
well im not positive but im pretty sure cummins have been glow plugless since 1989 so that would mean theses engines ignite on compression ignition. im sure someone will explain all of this much better than i can.
97: rclb totaled 9-4-10
95dodgectd is offline
post #3 of 12 (permalink) Old 08-04-2007, 09:08 AM
bucket truck's Avatar
Cummins doesn't use glowplugs. They use an intake heater or grid heater. All 6 cyl. diesels big or small use this setup. Now V8's like Duramax and Powerstroke have glowplugs b/c of the layout of the V8. But all Cummins do have a heater, but it usually it's used at a lower temp. This time of year they are just not needed. Maybe why do don't get a light. Mine won't stay on more than 1 sec in the morning. Below 55* is when they start kicking in, I believe.
bucket truck is offline
post #4 of 12 (permalink) Old 08-04-2007, 09:38 AM
upnorth's Avatar
If you check your book under instrument / gauge cluster, the pictogram indicating your grid heater is on, is a coil that will stay on if needed. If not needed, it will not lite.
07.5 2500 QC 6.7 68rfe, n-fab step & pre runner light bar,BW flares, striker 170, 295 Toyo MT,
upnorth is offline
post #5 of 12 (permalink) Old 08-04-2007, 09:43 AM
Duluth Diesel's Avatar
Cummins 5.9 and 6.7, never had glow plugs. Too prone to failure. The grid heater is a better design.
-Chuck
Duluth Diesel is offline
post #6 of 12 (permalink) Old 01-20-2009, 08:17 PM
Hemi
iTrader Score: 5 reviews
If your heated grid went out you would just have a little bit of trouble starting it in the cold.
4th gen bumpers do NOT belong on 2nd gens...
mjd91 is offline
post #7 of 12 (permalink) Old 01-20-2009, 08:20 PM
kenny110482's Avatar
It would have to be around zero to have any no starting issues. Alot of guys on here pull them out.
99 2500 Built Auto
SOLD Mineral Grey 2008 Dodge 3500 QCLB 4x4, Auto, Stock.
SOLD Black 2003 Dodge 2500 QCSB
kenny110482 is offline
post #8 of 12 (permalink) Old 01-20-2009, 08:50 PM
Grid heaters (intake manifold heaters) are much more reliable than glow plugs and rarely fail.
post #9 of 12 (permalink) Old 04-30-2011, 01:25 PM
dr.olds4554's Avatar
Is there a grid heater just for the fuel in addition to the one under the intake horn?
08 2wd . DPF,Heatgrid,CVC deletes. EFI LIVE from Anarchy. Modified intake horn. Fuel rail plugged. Straight piped, Valair quiet ceramic DD, Delvac 50-7qts.
dr.olds4554 is offline
post #10 of 12 (permalink) Old 04-30-2011, 04:10 PM
The grid heater is the one under the intake horn, and heats the intake air.
There is a fuel heater near the fuel filter to help prevent fuel gelling.
2008 6.7 Quad cab SB, G56, 3.73, black, Edge Insight, 285-70/17 BFG, Bilstein 5100 shocks, MagHytec rear diff cover, otherwise all stock.
2000rpm is offline
The Following User Says Thank You to 2000rpm For This Useful Post:
dr.olds4554 (05-24-2011)
post #11 of 12 (permalink) Old 04-30-2011, 05:54 PM
Diesel Filled Veins!
Sandman76's Avatar
To give you an idea of grid heater reliability, my old 2001 had 485 000km on it, living all it's life in frigid Alberta, using the grids except about 3 months of the year. I did put in a new set of relays back at around 450 000km, but the grid heaters have never failed on that truck. In the real cold the grids would fire for about 20 seconds. As a Ferd guy how many times he's replaced glow plugs
#3 ATS Stage IV - So Far So Good
EPA "Race Tuned" with EFI Live By DaveMatthews, Edge CTS; Fred Goeske dually spacers
2008 - - M - E - G - A - DUALLY - -
Sandman76 is offline
post #12 of 12 (permalink) Old 04-30-2011, 08:30 PM
insane3639's Avatar
iTrader Score: 6 reviews
To correct you EVERY diesel is run off of compression ignition no matter what a glowplug simply warms the cylinder if its to cold out to help in compression ignition
and another correction not EVERY 6cyl uses grid heaters most OTR trucks do not have them those are all inline 6cyl
2007.5 SOLD.
2005 SOLD.
1994 12 VALVE PROJECT
insane3639 is offline
