68RFE Transmission Filter - Dodge Cummins Diesel Forum
post #1 of 24 (permalink) Old 03-31-2010, 03:48 PM Thread Starter
Does anyone know what the micron rating is for the spin-on transmission filter?
I was just wondering.
Kevin
2009 RAM 3500 Laramie Mega Cab 4WD|6.7L|68RFE|SWD|SB|SRW|Mineral Gray Metalic|Mag-Hytec Trans+Rear Diff Covers|aFe Front Diff Cover|Edge Insight CTS|Aluminess Front Bumper|FabFours Rear Bumper|Carli Starter Suspension|FS-2500 Bypass Systems (Engine+Trans)|Titan Fuel Tank|Dunlop Rover M/T Maxx Traction|Mamba M4 Rims
krowe111 is offline
post #2 of 24 (permalink) Old 04-20-2010, 01:45 PM
TTT
I have been wondering the same thing,
I add a spin on filter to the transmission of my older vehicles with the "in pan filter" (aka screen)
507caddy is offline
post #3 of 24 (permalink) Old 04-20-2010, 02:32 PM
Don't know the answer to your question, but have one of my own. Are there two filters on the 68? Does anyone know which ones to order from Geno's Garage? One is outrageously priced on the website, just wondering how much I should be paying for these filters.
2008 Dodge 2500, 6.7L Cummins, XRT, 5" TBE, S&B Intake
bbiltz is offline
post #4 of 24 (permalink) Old 04-21-2010, 09:19 AM
TECH SPECIALIST
The spin-on filter rating is about 60 microns. Actually, there is no specific rating. The performance standard for the filter specifies what percentage of particles must be removed by the filter for each pass, and that is a table with varying percentages for varying micron ratings. But it should remove the vast majority of anything 60 microns or larger. It will actually remove over half of particles 30 microns in size.
The 68RFE uses two filters: the flat sump filter (with a snout to connect it to the pump) and the spin-on cooler return filter. Don't know what Geno's or others charge. Mopar list price is $18.70 for the spin-on 05179267AC, and $33.80 for the 4x4 sump filter 05013470AC. All 2009 and later RFEs (both 2WD and 4x4) use the 4x4 sump filter. For 2008 MY and earlier, 2WD RFEs use sump filter 05015267AD, which is $35.20 list.
TransEngineer is offline
post #5 of 24 (permalink) Old 04-21-2010, 10:30 AM
Hired Gun's Avatar
Transengineer is correct on the part numbers and Mopar prices. I just bought these this week. However I did talk them down on the $33.80 filter. I got it for 27.00. I had to try and hey I saved some cash.
Hired Gun
2013 White Crew Cab DRW.
Hired Gun is offline
post #6 of 24 (permalink) Old 04-21-2010, 11:35 AM
The book says 60,000 miles if towing. Curious how many miles you guys are changing at? I'm at 22,000 now, mostly towing.
2008 3500 Big Horn SRW LB 4X4 Auto White P3 Trailer Brake Control
coolbreeze is offline
post #7 of 24 (permalink) Old 04-21-2010, 11:52 AM
LittleOleHotShotter's Avatar
I changed mine every 30k miles. Lasted 230,000 miles
TRUCK IT TRANSPORT
LittleOleHotShotter is offline
post #8 of 24 (permalink) Old 04-21-2010, 12:47 PM
johndeerrm's Avatar
Can you get to the spin on filter without removing the pan?
2010 RAM 2500 Laramie Crew 4x4 with the C option.
johndeerrm is offline
post #9 of 24 (permalink) Old 04-21-2010, 01:33 PM
TECH SPECIALIST
Sorry, no. The cooler return filter (spin-on) is inside the pan, at the right front corner.
post #10 of 24 (permalink) Old 04-22-2010, 12:28 AM
Put a mag cover on for easy drains..well worth it IMHO.
Tonka
jandpc4176 is offline
post #11 of 24 (permalink) Old 04-22-2010, 07:40 AM
You're wrong! Get over it
dad2bike's Avatar
I changed my fluids, filters and the pan at 15K. Only because I'm old-school and wanted to get any break-in particles out of the system. To be honest, the fluid was very clean. Nothing noticable. I did the diffs & covers at the same time. Now that's where I found some break-in particles. I put Mag-Hytech covers all around. Got them from RSD. They were at my doorstep in 2 days.
Tom
2008 QC-LB,2500,4X4,White/Kaki,Big-Horn,3.73 Auto, MyGig Nav unit, K&N no baffle,DPF quit working, GHD, Shibby stage 1 intake & boost tube, Smarty, PMT for gauges, Mag-Hytec Pan & Diff covers.
SNAFU
dad2bike is offline
post #12 of 24 (permalink) Old 04-22-2010, 02:03 PM
just a heads up on a stupid mistake when changing trans fluid, when checking the trans fluid be sure not to hit the pos batt cable with the dip stick it will fry the alternator.
nickb78 is offline
