Replacing the Serpentine Belt Help - Dodge Cummins Diesel Forum
post #1 of 30 (permalink) Old 07-04-2009, 04:20 PM Thread Starter
Burnin'Bevo's Avatar
Tore my belt this morning...does anyone know how to get the belt off???
2008 MegaCab 6.7L Silver 4x4 SXT; Banks CAI; RSD 5" TBE; XRT; Shibby Boost Tube and GHD; BOD Intake; AutoMeter Boost/Pyro/Trans; EPP; AmpResearch PowerSteps; 20" Moto Metal 956's; MT Baja MTZ 35x12.50;
Burnin'Bevo is offline
post #2 of 30 (permalink) Old 07-05-2009, 11:05 AM
Jim W's Avatar
There should be a pre-tensioner pulley that applies constant tension to the Serpentine belt. This is shown in the belt diagram on the fan shroud. You put a 1.2 drive ratchet in the center square hole and turn to release the tension on the belt. Remove the belt and install the next one, also relieve tension on the pulley as you place the new belt on the other pulleys.
Hope this helps you.
2008 3/4T, Mega Cab SLT, 6.7L CTD 68RFE,Optix Gauges Pyro, Boost, Trans Temp A Piller mount, Mag-Hytec Trans Pan, Front & Rear Diff cover,Smarty, MBRP Exhaust, Silver, Westin Side Steps, Line-X Bed Liner, Bed Cover, Prodigy BC, 15K Reese hitch and pulling a 11K 5er
Jim W is offline
post #3 of 30 (permalink) Old 07-05-2009, 12:56 PM
RATLIN'HP
Guest
Posts: n/a
I had a couple of kittens take mine out almost exactly a year ago. Pain in the a$$. No diagram to show you how it goes back on. Had to have dealer fax me a diagram, what ever happened to the sticker under the hood?
post #4 of 30 (permalink) Old 07-05-2009, 03:52 PM
my cab and chassis also had no diagram I replaced the belt while i did the water pump and it took longer to figure the belt out than to install the pump.
Goat08 is offline
post #5 of 30 (permalink) Old 08-01-2009, 07:40 PM
I had to change out the alternator. No problem, however, I am having TROUBLE getting the drive belt back on!
richard1 is offline
post #6 of 30 (permalink) Old 08-01-2009, 10:12 PM
You're wrong! Get over it
dad2bike's Avatar
You can get a tool similar to this one for taking the belts off/on at AutoZone for about $20. I wish I had bought one sooner.
Amazon.com: BELT TOOL SERPENTINE AND ACCESSORIES: Automotive
Tom
2008 QC-LB,2500,4X4,White/Kaki,Big-Horn,3.73 Auto, MyGig Nav unit, K&N no baffle,DPF quit working, GHD, Shibby stage 1 intake & boost tube, Smarty, PMT for gauges, Mag-Hytec Pan & Diff covers.
SNAFU
dad2bike is offline
post #7 of 30 (permalink) Old 08-01-2009, 11:43 PM
Thumbs up
Thanks for the input! Being this is my first time on the Forum, I hope this response gets out. Again, thanx! Job complete!
richard1 is offline
The Following 2 Users Say Thank You to richard1 For This Useful Post:
boostedcummins5.9 (07-16-2013), no_more_strokin' (03-28-2015)
post #8 of 30 (permalink) Old 08-02-2009, 01:34 AM
Ok putting the belt on works best with 2 people. it can be done with one but its a pain. The back of the belt is going to have to go on the tensioner first. The tesnioner will have to be lossened first. It takes a 13mm socket or wrench. From there it goes around the crankshaft damper, around the fan pulley, around the powerteering pulley, around the pulley at the very top of the engine, down to the waterpump, up to the alternator pulley,down the the a/c compressor,then back to the tensioner. laptop battery dying pm me for details.
pricklypete is offline
post #9 of 30 (permalink) Old 08-02-2009, 05:17 PM
Thumbs up Thanx for the input everone!
Thanx, pricklypete, for your help. The main problem I was having was I did'nt know the belt tensioner was spring loaded. After that, it was possible to put a 3/8" drive ratchet in the hole to pull back the tensioner to enable the belt to be positioned. By the way, I drive a '97 excab 3500 dually that I use to pull a 5th wheel trailer with.
richard1 is offline
post #10 of 30 (permalink) Old 08-03-2009, 12:25 AM
Sorry about that, I was giving belt info for the 6.7L I didn't realize we were talking 5.9
post #11 of 30 (permalink) Old 09-06-2009, 06:18 PM
Once person CAN (easily) release the tensioner!
Just replaced my water pump on 2003 5.9 today, 135,500 miles. Engine had been running a little warmer the past few days, but there was no evidence of coolant weeping until this morning.
I'd like to add that once I understood how the tensioner worked with the 1/2" ratchet (hard to see between the fan the blades!), the whole replacement time took about 1 1/2 hrs.
I went from underneath the truck with the ratchet and used a ratchet strap wrapped around the 1/2" drive ratchet handle, tied to the bumper. Cinch up the ratchet, pulls the ratchet handle pulling the tensioner back. Left it in place until done, slid the belt back in place and release the ratchet strap, checking the belt is in place correctly. Jim
'03 Ram 3500, BullyDog on Tow Mode, Edge Mileage Max, CFM Intake running on B100. BioPro dealer.
recmob is offline
post #12 of 30 (permalink) Old 09-26-2010, 02:07 PM
Serpintine or drive belt and speed sensor
Hi all new to this forum. My drive belt or serpentine belt frayed and I am replacing it. I am a female and love my truck. But there is a note in my owners manual that states I must check the engine speed sensor near the damper. Ok really confused now. Where are they and what do they look like. How do I check them? What do I look for. Also you stated two people to replace this belt. Oops only little ole me. Please, help.
reallyunique dodge lover is offline
