How to Remove Injectors - Dodge Cummins Diesel Forum
post #1 of 15 (permalink) Old 11-07-2008, 06:15 PM Thread Starter
GreenDieselPower's Avatar
Okay I want to remove my injectors and install some 40 or 80hp So before I start this crazy project does anyone have pics or instructions to do this? Who should I go with Industrial or DDP? Should Install the Bag of parts from industrial? Do I need to put a programmer for this mod?
2004 Ram 2500 5.9 looking for upgrades
GreenDieselPower is offline
post #2 of 15 (permalink) Old 11-07-2008, 06:32 PM
Skrew- EPA CARB OPEC PETA
harvey4804's Avatar
IMO, for that injector size, the bag of parts might not be necessary sine the 6.7 CP3 has a higher flow rate but it could help. As far as what brand... everybody has there own opnions. A programmer may not be necessary but it would help gain the full potential of the injectors. An upgraded turbo would also show great improvements in conjunction with the injectors. Hope this helps some.
2004.5, QC, LB, Crapomatic, 4x4 Factory Nav. AirDog 100, Arson Kit, AEM Bruteforce HD, Silverline 5" t409, BMK-11, Mag-Hytec, Bilstein 7100, B&W, Tekonsha P3, DiPricol's, 315/70/17 Cooper AT3, Black Cragar's, PacBrake bags, Aluminum Doghouse Driveshaft, Smarty POD Revo
Former HMX-1 Executive Flight Detachment Avionics Technician
KK6JYX
harvey4804 is offline
post #3 of 15 (permalink) Old 11-07-2008, 07:58 PM
SRT6.7's Avatar
iTrader Score: 4 reviews
usually from what i saw they send you a tool to remove the injectors when you purchase them.
TOY=07.5 SRT6.7 full build With BD Diesel Triple 74mm's many many pesos invested
--2015 sublime challenger HELLCAT manual
--06 2500 4x4 - caged race ready project truck no motor no Trans for sale 9k
SRT6.7 is offline
post #4 of 15 (permalink) Old 11-08-2008, 03:18 AM
SoTexSmokin's Avatar
they send you a tool for removing the nozzle tips themselves not the whole injector. and harvy4804 the have no aftermarket upgraded turbos yet for the 6.7. The injector instalation is pretty straight forward remove the valve cover high pressure lines then i think it is a 22 mm nut that holds the injcetor feed tubes into the side if the head, remove those then number your injectors 1,2,3 etc (the 6.7s remember the particular injector for that cylinder) then remove injector hold downs and pop them out. the tool the send you put in a vice and hole the injector body with and get a wrench (dont remeber what size) and break the nozzles off. then reverse order put new nozzles one and reinstall back in the truck remembering to put each injector back in the same cylinder torque to spec and your done. truck will crank for a few seconds to a minute then fire might run rough for a minute or two and smoke slightly but it will clear up... Hope this helps, i know its kind of a generic reply but there is rreally not that much too it!
08 mega cab Some things added some things fell off.... This and that I guess.
98.5 dually
SoTexSmokin is offline
post #5 of 15 (permalink) Old 11-08-2008, 03:22 AM
oh and when you reinstall your injedtor feed tubes they have two detent balls on them make sure those are facing straight up
and as far as your question about which manufacturer to use... I have had both ( not in my 6.7 ) and I prefer dynomite diesel
98.5 dually
post #6 of 15 (permalink) Old 11-08-2008, 03:31 AM
harvey4804's Avatar
Dang, no aftermarket turbos for the 6.7 yet... didn't know that
KK6JYX
post #7 of 15 (permalink) Old 11-08-2008, 03:35 AM
yessir we are patiently waiting TRUST ME!!! lol
98.5 dually
post #8 of 15 (permalink) Old 11-08-2008, 09:42 PM
bmorgan's Avatar
Injectors are not that hard to install, didn't take pictures of it, but i am sure someone out there has some. And just so you know the bag of parts for the modified CP3 is not $350 as it says on the II website. It is $750 so expect to fork out double for it compared to the 5.9L.
2008 mega cab 3" lift, 08.5+ steering upgrade, box stabilizer, 5100's all around, 35" tires on stock blacked out rims, 2" wheel spacers, afe pans, 4" flo pro, spectra vgt "POS'S" out, bd super B special kit in, xrt pro w/ OD, edge cts, deleted, recons....more to come I'm sure...
-Sold-07.5 Mega Cab compound turbo 700 hp 1500 tq
-Sold-04.5 2wd drw qclb hauler, 500hp
-Sold-2011 mega short bed drw
bmorgan is offline
post #9 of 15 (permalink) Old 11-11-2008, 11:59 PM Thread Starter
Thanks for the info.
If anyone has any pics please feel free to post them. Thanks
post #10 of 15 (permalink) Old 11-12-2008, 02:01 AM
go on dynomites website and they have detailed step by step instructions, im sorry I wish I had taken some but fogot the camera that day
98.5 dually
post #11 of 15 (permalink) Old 11-12-2008, 07:13 PM
CF Administration
KMKDIESEL's Avatar
iTrader Score: 9 reviews
$750 were did you get that info I was told $100 more than the 5.9 kit and when my card was charged by my warehouse they only charged the 5.9 price but they might have been charged $100 more from II and just screwed up charging me
-Nic - Idaho Oil Burners President
2009/ 3500/ Laramie/ Mega Cab/ Electric Blue/ Blackmaxx MCC tuned/ATS Stage 6 48re/ TS Mp8/ 5" Dual Exhaust/ 66-74-14/ Pdi manifold/ 50% over nozzles/ H&S Intake Horn And Boost Tube/ Afe stage 2 CAI/ Stage 1 Cp3/ GDP Maximizer Kit/ Shaved,Flycut,Coated Pistons/ A1-H11 Headstuds/ GDP CCV Kit/ 8" Lift/ 37" Toyos. 648 hp 1351 tq uncorrected
1996 12v 2.8 puller "dominate this"
R.I.P. Tucker
KMKDIESEL is offline
post #12 of 15 (permalink) Old 11-12-2008, 07:19 PM
jjpage's Avatar
Richard also has pictures with detailed instructions on his Glacier Diesel Power
Hope that helps.
2003 HO 3500 SRW QC, DTT 48RE
MBRP 5" T/B EXH, Dipricol Gauges
jjpage is offline
